Play MXF on Mac-Transcode Panasonic P2 MXF to QuickTime MOV
Postod kelly456 » 22.10.2012 11:07
Working with AVC-Intra Footage-play QuickTime MOV on Mac
Summary: Follow this article you will know the easiest method to convert Panasonic P2 card MXF to QuickTime MOV on Mac for watching freely.
In recent years, professional High Definition camcorders like Panasonic P2 camcorders, Canon XF series camcorders and Sony XDCAM camcorders which output .mxf HD video files are becoming more and more popular with its professional and amazing shoot and capture functions. Have you one of the owners of these professional High Definition camcorders. Ever thought of play the MXF files with QuickTime on your Mac? This article will take Panasonic P2 camcorders as example and show you how to convert P2 card MXF files to QuickTime MOV on Mac.
Many people are new to high-definition camcorders and P2 card MXF format, play P2 camcorder .mxf on QuickTime is not a simple thing for most of us, when you import your P2 card MXF file to QuickTime, you will find that the MXF Files which you want import into QuickTime are greyed. Why this happen, why you can't import P2 card mxf file to QuickTime, and if you wanna play P2 card mxf file with QuickTime what should you do? Don't worry, here the tutorial will tell you how to convert P2 card mxf file to QuickTime .mov and how to play P2 card mxf on QuickTime.
Steps: Convert Panasonic P2 card MXF to QuickTime MOV on Mac
1.Download, install and launch Pavtube MXF Converter for Mac.
Once launched the program, click "Add Video" button to load your P2 card MXF clips. You are allowed to add multiple files to convert at a time.
2.Select output format.
Click on the dropdown menu of "Format" and select "Common Video -> MOV – QuickTime (*.mov)" as target format. This format is specially designed for QuickTime playback. You can also choose format as you need in the format column, such as AVI, MKV, MP4, etc.
3.Adjust video and audio parameters.
Click "Settings" button to customize the output video and audio settings by yourself. You can also use the default parameters, they will ensure you a good balance between file size and image quality basically. You can change the resolution, bitrate, frame rate as you need.
4.Click convert button to start to convert P2 card file to QuickTime MOV on Mac with this best P2 card Mac converter.
After you converting P2 card MXF files to MOV for QuickTime, you can play the converted footages smoothly on Mac. With the Mac P2 card to MOV converter, you can easily convert P2 card MXF file on Mac, you can also convert P2 card MXF file to other formats with best video and audio quality, like Canon MXF to iMovie/FCE, and P2 MXF to FCP.
Tip:
Hot News! you can use Pavtube DVD Creator for Mac to burn MXF video to DVD for managing, storing, playback or backup etc. You can get 50% off now. Just take a try!
Compare Free version with Retail version
