AVCHD to ProRes-Convert FS100 AVCHD to ProRes for FCP 7/X
Postod kelly456 » 14.10.2012 4:12
Edit Sony NEX-FS100 1080p AVCHD in FCP 7/X with ProRes 422 codec
Summary:Follow the guide below and you will know how to import Sony NEX-FS100 AVCHD to Final Cut Pro 7/X without rendering on Mac.
Sony NEX-FS100 is an interchangeable lens camcorder featuring a Super 35mm sensor equivalent in size to Super35mm film cameras ( same as PMW-F3), and a Sony E-Mount 18 to 200mm zoom lens. Developed specifically as a digital motion camcorder, it captures fine detail and image texture with image fidelity, low noise and wide exposure latitude.
This camcorder features 1920x1080P Slow and Quick Motion (Over & Under Cranking). Recording images at a different frame rate from that used for playback provides the extra versatility of slow and quick motion shooting. The NEX-FS100 enables Full HD (1920×1080) progressive slow and quick motion. S&Q shooting plus last scene review permits checking the S&Q effects on-set, immediately after shooting the scene without drilling down menus.
Sony FS100 camcorder records AVCHD format video, and it uses MPEG-4 or MPEG-2 codec, this codec is not good for editing in FCP, and you will encounter importing and codec problems when you try to import Sony FS100 AVCHD to FCP 7/X or Avid Media Composer.
FCP 7/X best supported video format is Apple ProRes 422 codec MOV format, so the best method to solve Sony FS100 importing and codec problem is to convert Sony FS100 1080P AVCHD footage to ProRes for editing in Final Cut Pro, you can follow the steps below to transcode Sony FS100 files to FCP for editing.
1.Download Pavtube AVCHD to FCP Converter. This professional HD Video Converter can help you convert Sony FS100 AVCHD 50/60P files to ProRes 422 MOV format for Final Cut Pro, more import and output formats are also supported.
2.Install and launch this AVCHD to Final Cut Pro Converter. Import Sony FS100 footage to the converter.
3.Click "format" bar to choose the output format. Click and choose "Final Cut Pro -> Apple ProRes 422 (*.mov)" as Final Cut Pro 7/X compatible codec for editing AVCHD MTS in FCP better.
4.You can click "settings" to customize the output parameters, adjust the resolution, bitrate as you want.
5.Click convert button to start transcode Sony FS100 AVCHD to ProRes MOV for FCP on Mac.
The steps are finished. Is it easy? Once you have installed the Sony AVCHD to FCP X converter, you can easily convert Sony FS100 files to FCP 7/X for editing, this software runs fast, so you can convert your FS100 footages to FCP in less time, video and audio synchronization are perfectly guaranteed, and you can use accurate trim function when you edit Sony AVCHD video in the software before conversion.
Related Link:
Import 50p/60p AVCHD to Final Cut Pro (X)
Load Sony A77 AVCHD MTS/M2TS to FCP X
Make Sony HDR-SR1 MTS footages editable in FCE
Import Sony NEX-VG20 AVCHD to FCP 7/X
Import Sony NEX-5N/NEX-7/A57/A65/A77 1080p AVCHD to iMovie
Convert Sony Handycam AVCHD video to MP4
Hope these guides can help you deal Sony Camcorder video easily.
Re: AVCHD to ProRes-Convert FS100 AVCHD to ProRes for FCP 7/
Postod kelly456 » 02.02.2013 8:58
Why Hauppauge PVR footage won't import into FCP ?
Summary:In this article, you will know how to import Hauppauge PVR AVCHD footage to final cut pro for editing on Mac.
If you are experienced in video recording, you must be familiar with Hauppauge HD PVR. HD PVR is the world's first High Definition video recorder for making real-time H.264 compressed recordings at resolutions up to 1080i. HD-PVR records component video (YCrCb) from video game consoles and cable TV and satellite set top boxes, with a built-in IR blaster to automatically change TV channels for scheduled recordings. Audio is recorded using two channel stereo or optical audio with five channel Dolby Digital.
Have you encountered problems like this?
"I have h264-encoded movs of videogame footage captured with a Hauppauge HD PVR. Final Cut 6 and 7 both refuse to ingest them, though QT Pro will open them. Even if I transcode with QT Pro to ProRes (HQ), Final Cut will not recognize the file. Has anyone else encountered this, or found a workaround for it?”
How to solve the HD PVR footages to FCP problem?
First, let's know more about its recording format:
From Hauppauge HD PVR official website, you will know the recording format is AVCHD, which can be used to burn Blu-ray compatible discs. Two hours of HD recordings, recorded at 5 Mbits/sec, can be burnt onto a standard 4.7 GByte DVD-R or DVD-RW disc for playback on a Blu-ray disc player.
There are three H.264 formats you can choose when recording a video:
.TS, which is a generic 'transport stream' compatible with many digital media players
.M2TS, which is compatible with the Sony Playstation3
.MP4, which is compatible with the XBox360
Solution:
The Hauppauge HD PVR recordings is MP4 or AVCHD TS/M2TS format, these formats are not supported by many editing software, including FCP (X). So if you want to transfer Hauppauge HD PVR 1080p AVCHD files to FCP (X) , you need to convert first. FCP (X) best supported video format is Apple ProRes 422 codec MOV format, so if you convert Hauppauge HD PVR AVCHD to ProRes 422 format, you can edit Hauppauge HD PVR footages in FCP (X) smoothly without rendering.
Now you can download Hauppauge HD PVR AVCHD to FCP converter, you will see the interface as showed below:
You can choose prores 422 for final cut pro editing, this output format will solve your Final Cut Pro importing problems. So take a try now!
If you need to burn video to DVD disc/ISO/folder on Mac, you can try Pavtube DVD Creator for Mac, in the Christmas promotion activity, you can get this DVD Creator for free if you buy converter product, and get other software at up to 40% off. With it, you can also burn Humax 1080p recordings to DVD on Mac.
Learn more Canon Cameras/Camcorders related tutorial, pls view our FCP Column, etc. on http://www.pavtube.com/hot-topics/
Postod kelly456 » 08.07.2013 10:41
Cheap Summer Holidays & Deals-Up to 50% off get best video tools to convert HD videos
Summer Break is starting now. It's time to have fun: hanging out with friends, spending some quality time with family members, enjoying personal space alone. No matter whom you are with or where you are, watching movies, sharing online videos or editing video footages would be a part of your summer holiday more or less. While a great video converter would be essential in your summer break if you want to do above stuff, and Pavtube software application is a perfect choice.
Great news! Pavtube is offering up to 50% off Special Summer Holiday Discount for its top programs, including Blu-ray Ripper (Win & Mac), Video Converter Ultimate (Win & Mac), Media Magician (Win & Mac), and DVD Creator (Win & Mac). Plus, Like Pavtube on Facebook and you would get an extra 5% off discount from above products!
Expires on July 31, 2013. Time-Limitted! Never miss!!!
Let's get familiar with Pavtube programs!
1. Pavtube Video Converter Ultimate for Win/ iMedia Converter for Mac with 20% off
Pros: integrates a blu-ray ripper, a dvd ripper and a video converter which allows regular SD video clips, camera recorded HD footages and online downloaded videos as source media, meanwhile purchased or rent Blu-ray and DVDs are its specialty too.
More tips for you:
Convert Blu-ray/DVD movies to Apple TV 3
Transfer movies to Galaxy Tab tablets from Mac
Stream DVD, Blu-ray, 1080p HD Videos to PS3
Import Media Files to Premiere Pro on Mac
Transfer Blu-rays to iMovie/FCE for editing
Rip Blu-Ray HD contents to Final Cut Pro
Convert a dvd for FCP(X) editing
Work with DVDs in iMovie
Pavtube Video Converter Ultimate-Faster DVD Ripper and Converter
2. Pavtube Media Magician for Win/Mac with 50% off
Pros: Regarded as a nice camcorder assistant manager; lossless output MTS/M2TS/MOD/TOD videos to original format or MKV; edit timeline without rendering; directly output video friendly with video editing programs or uploaded to YouTube.
See more articles:
Convert Sony HDR-XR160E MTS into MP4
Importing Canon EOS 650D video to Sony Vegas
Merge Sony DSC-H200 MP4 for Sony Vegas,Avid MC,Pinnacle Studio
Edit XAVC Video Footage in iMovie/FCE
Sony Cyber-shot TF1 workflow on Mac
Get Sony NEX-5R MTS Videos into iMovie 8/9/11
Work with Panasonic TM900/HS900/SD900 MTS in iMovie/FCE
Transcode Sony SR1 MTS to Premiere Pro
Media Megician Users Guide
3. Pavtube DVD Creator for Win/Mac with 50% off
Pros: burn playable DVD from DVD folder and ISO image within a few clicks; freely edit source material by trimming, cropping, adding watermark, etc; customize DVD menu template /style, menu text, display aspect ratio and background.
Read more:
Panasonic AVCHD MTS to DVD
Best way to burn huge TiVo video to DVD disc
Canon EOS to DVD converter-Burn Canon MOV to DVD
Convert Panasonic AG-HVX200 MXF for DVD burning
How to burn Sony Handycam MTS to DVD?
How to rip and burn a Blu-ray Disc to DVD?
Make a DVD from Sony PMW-400 XAVC video
Effective Way to Burn Sony XAVC clips to DVD on Mac
Free Burn AVI, MKV, MP4 to DVD on Mac
Quick burn DVD folder to DVD on Mac
Burn MXF to DVD disc without Apple iDVD on Mac
Burn YouTube videos/Vimeo/Torrent movies to DVD
4. Pavtube Blu-ray Ripper for Win/Mac with 30% off
Pros: fully backup commercial Blu-ray and DVD discs; rip Blu-ray and DVD to many formats, such as .MP4, .MKV, .MOV, etc; support output playback on various portable devices including tablets (the new iPad 3, Galaxy Tab 3, Toshiba Thrive, Nook Tablet, Amazon Kindle Fire) and mobile phones (Samsung Galaxy S4, HTC Evo 4G, iPhone 5), HD media player such as Apple TV, WDTV, PS3, and video editing programs like Sony Vegas, Adobe Premiere, FCP, iMovie.
Related Guides:
Backup Blu-ray titles to Nexus 10 on Mac
How to stream Blu-ray movies to Popcorn Hour A-400
How can you appreciate Blu-ray Content material on Western Electronic WD TV Live
Top 5 Best Blu-ray Ripping Programs Review
2013 Top Mac Blu-ray Ripping Review for Android, Apple iOS and Windows 8 Devices
Interested? Hurry up, the Special Summer Break offers expires on July 31, 2013. Never miss!!!
