Import Sony NEX-5N AVCHD to Final Cut Pro and Avid MC 6
Postod kelly456 » 11.09.2012 11:47
Import Sony NEX-5N AVCHD to Final Cut Pro and Avid Media Composer 6
Summary: Follow this guide you will know how to Import Sony NEX-5N AVCHD to Final Cut Pro and Avid Media Composer 6.
Sony NEX-5N is one of the excellent compact cameras which has the ability to capture HD video at 1080/60p. This makes for smooth motion. With the recent update of Final Cut Pro X and AMC 6, I was hoping both software would add support for 60P/50P AVCHD; however, seems it did not. As a result, working with video from cameras shooting 60p AVCHD 2.0 footage (like the Sony NEX-5N) brings a bit of a problem when importing the files from your camera.
The quick workaround is to rewrap the Sony NEX-5N AVCHD 1080/60p files. As to keep the HD video quality and avoid rendering, I would like to use the Apple ProRes codec in FCP and DNxHD codec in AMC. The two codecs are the best codec for each editing software, so the best way is to convert Sony NEX-5N AVCHD to ProRes for FCP or Transcode AVCHD to DNxHD MOV for Avid Media Composer on Mac.
Now I will start with the step-by-step guide on how to convert Sony NEX-5N AVCHD 1080/60p MTS/M2TS to ProRes 422/DNxHD and then import the converted videos for editing.
Free Download Pavtube Sony AVCHD MTS Converter for Mac.
Step 1: Run the best Mac Sony AVCHD Converter, and import your Sony NEX-5N AVCHD file.
Step 2: Click format column and choose the output format. You are recommended to choose Final Cut Pro -> Apple ProRes 422 (*.mov) as the best codec for editing AVCHD in FCP, this codec is optimized for FCP;
You can also choose Avid Media Composer -> Avid DNxHD (*.mov) as the best codec for editing AVCHD in Avid Media Composer 6.
Step 3: Click settings button to adjust the output video's parameters, such as bitrate, resolution, etc.
For Final Cut Pro users
For Avid Media Composer users
Step 4: Start converting Sony NEX-5N 1080/60p AVCHD videos to Apple ProRes/DNxHD for Final Cut Pro and Avid Media Composer 6.
After the Sony NEX-5N AVCHD conversion, import the converted MOV files to Final Cut Pro, then you can edit Sony NEX-5N videos in FCP and AMC smoothly. You can find more guides in Pavtube MTS Column and FCP column.
And now you can join buy one get one promotion activity on Pavtube website.
