How to convert PDF to Microsoft PowerPoint(*.pptx) on Mac?
Postod abcmac83 » 06.03.2012 4:04
PDF to PowerPoint Converter for Mac, the first and best solution to convert PDF to PowerPoint presentations on Mac. It enables users to make a dynamic PowerPoint presentation quickly and efficiently by recovering PowerPoint presentations from PDF slides. Just download the PDF to PowerPoint Converter for Mac and install it on your Mac.
Launch the program to have a free trial. Then follow the 3 simple steps below to convert PDF to Microsoft PowerPoint on Mac OS X now:
Step One: Import PDF files you want to convert
Drag and drop PDF files into the panel to import PDF files for conversion.
Step Two: Settings
Choose "PDF to PowerPoint -> Preferences" in the menu bar, you can set the output folder for the converted PowerPoint(*.pptx) presentations
Then choose "File-> Output Settings-> File Configuration" in the menu bar, or click on the gear icongear beside the PowerPoint icon, it is easy to customize the page ranges for the output file. The default options are All pages.
Step Three: Converting PDF to PowerPoint(*.pptx) on Mac
Click "Convert" button to convert PDF to PowerPoint(*.pptx) on Mac OS X. The conversion will be finished in seconds. Then you can click on the PowerPoint icon to open the converted PowerPoint file.
PDF to PowerPoint for Mac, how to convert pdf to powerpoint, how to convert pdf to ppt
PDF to PPT Mac, pdf to PowerPoint, PDF to PPTX, change pdf to powerpoint, export pdf to powerpoint
abcmac83
Postova:  67
Korisnici koji su trenutno na forumu: Nema registrovanih korisnika i 12 gostiju
