Android ISO - Put DVD ISO files to Android Tablets
Postod JeanLiu » 13.11.2014 12:01
Convert DVD ISO to Android Tablets for playback freely
Nowdays, in order to keep Blu-ray discs from scratching, or manage their movies in a more convenient way, many folks are fond of backing up their DVD discs into ISO image files. However, ISO files are not easy to playback with Android Tablets. So there are many reasons why you want to convert DVD ISO image files to H.264 or MPEG-4 videos, for instance, play the movies on Asus Transformer Prime, Google Nexus 7, Nook Tablet, Galaxy Tab and more. The process is quite easy than you may think. Below, I will throw this quick tutorial up, guaranteed to play DVD ISO movies on your Android Tablet.
See also: Top 3 Best DVD Players
Requirements
Before anything else, you have to download an app that you are going to use later. You are recommended to download and install:
Pavtube DVDAid (available for Windows or for Mac users and currently on sale). Get the Windows version here, and the Mac version here.
Instructions
The program is an easy-to-use yet professional ISO to Android Converter. It is easy to use for editing and conversion and good at dealing with DVD discs, DVD iso/ifo image files even DVD Folders. The audio/video synchronization is very good, the size of the subtitles too. The encoding speed is faster. I've had success using the software to convert DVD ISO to a friendly format by my Nexus 7. I've found the quality to be excellent, and see no difference when compared to playing the ISO movies themselves. Just free download it and follow the steps below to copy DVD ISO image files to your Android Tablet for playing in just a few clicks.
Convert DVD ISO to H.264 MP4 videos for Android Tablets
1. Run the program, and add your ISO image files to the software.
2. Select an Android friendly format, e.g. H.264 .mp4 for conversion. There are optimized format for Galaxy Tab, Xoom, Acer Iconia Tab, Asus Transformer etc, Google Nexus 7, Kindle Fire. Basically the 'Common Video >> H.264 Video (*.mp4)' is an universal format for Android tablets and smartphones. Or depends on your device, you can choose a suitable video format from "Android" catalogue. (Android Support Video/Audio Formats)
Tips: You can adjust the output parameters of the video by click 'Settings' button. Please remember the file size is based more on bitrate than resolution which means bitrate higher results in big file size, and lower visible quality loss.
3. Click the big Convert button to encode DVD ISO to MP4 videos for Android Tablet
The software will do the rest automatically. When the conversion finishes, you can click 'Open' to access to the converted MOV videos. In this way, you can transfer converted DVD ISO videos to your Android Tablet and enjoy them on the go!
All of the above video(including MKV, AVI, Tivo, VOB, FLV, MPG, DVD, Blu-ray, ISO, IFO, etc.), a software can be completely solved, it is Pavtube Video Converter Ultimate.
In addition, if you bought many videos from iTunes, Amazon, or BBC iPlayer store, you will find these videos are protected, here I highly recommended a DRM removal software.
ByteCopy($42) + Vidpie($29) = Only $54.9, Save $16.1
Video Converter Ultimate($65) + Vidpie($29) = Only $74.9, Save $19.1
Additional Tips
Android tablets only recognize SD cards formatted in FAT 32, this limits a single file size less than 4GB. If you worry about getting a big video file larger than 4GB, you can use split feature in Pavtube software to split a large 1080p/720p file into multiple chunks under 4GB. Learn to split a large video file into several small files under 4GB for Android device.
Not a Android users? It doesn't matter, the Pavtube Converter also supports "common" video formats like MOV, M4V, MP4 and has presets for all the models of iPad Air 2, iPhone 6 plus, iPod 5 and Apple TV 3, so you should be able to create files compatible with your iOS basd devices, as well as BlackBerry and Surface Pro 3, Surface Pro 2, Surface RT/Pro, etc.
Source: http://comfortable-media-device.over-blog.com/convert-dvd-iso-ifo-for-playback-with-android-tablets
See also:
JeanLiu
Postova:  443
