mport Sony HXR-NX5U AVCHD to FCP X/7/6 for Editing on Mac
Postod martylyy » 04.05.2014 16:48
The first in Sony's line of NXCAM solid-state camcorders, the Sony HXR-NX5U is also the company's first professional-level AVCHD camcorder. And while it may look similar to its HDV predecessor, the HVR-Z5U, in fact this is a very different animal. Its ability to capture HD and SD video in AVCHD and MPEG-2 formats--and save it to solid state media--is only one of its distinctive traits. Full-raster 1920 x 1080 video is another, including the option of recording 720/60p video as well as 60i, 30p and 24p. And because the NX5U can capture to media cards plus an optional flash memory unit, you can simultaneously record a different signal to each, whether HD + a backup or HD + SD. The footage is then easily downloaded to a computer or backup drive using USB 2.0.
Final Cut Pro X, the latest version of video-editing software geared for professionals from a company increasingly focused on mainstream consumers. Final Cut Pro X is a follow-up to Final Cut Pro 7, software Apple released in 2009 as part of Final Cut Studio. Like Apple’s newly released of Mac OS X Mavericks, Final Cut Pro X was only be available to customers through the Mac App Store. However, this new released FCP X does not support well with HXR-NX5U AVCHD Videos.
So if you want to edit Sony HXR-NX5U 1080 AVCHD Videos in Final Cut Pro X, you are recommended to use UFUSoft AVCHD Converter for Mac, which is the superior Mac Sony HXR-NX5U MTS to FCP X converter for Mavericks, Mountain Lion, Lion and Snow Leopard. It does not only convert Sony HXR-NX5U AVCHD to MOV on Mac, but also merges 1080 MTS files for import into Final Cut Pro X.
Here is the step-by-step guide for you to import and edit Sony HXR-NX5U MTS to Final Cut Pro X on iMac/MacBook Pro with Mac OS X like Mavericks, Mountain Lion, Lion or Snow Leopard.
Step 1. Load Sony AVCHD videos to UFUSoft AVCHD Converter for Mac.
After transferring .mts files from Sony HXR-NX5U camera, run UFUSoft AVCHD Converter for Mac as the best Mac Sony HXR-NX5U MTS to MOV converter, and click the “Add File” button to load .mts videos.
Step 2. Choose H.264/AVC MOV output format.
Click the “Format” option, and choose HD Video > HD MOV (*.mov) for converting AVCHD videos from MTS to MOV with H.264/AVC as video codec for loading to Final Cut Studio. With this option, the output video will be kept as high definition 1920×1080.
Step 3. Merge Sony HXR-NX5U AVCHD MTS files. (optional)
Select all the files and then click “Merge”, and the Sony HXR-NX5U MTS converter will join and combine the video clips into a single file as output.
Step 4. Convert Sony HXR-NX5U MTS to MOV for Final Cut Pro X.
Click the convert button under the preview window, the Mac Panasonic MTS converter starts converting Sony HXR-NX5U MTS videos to H.264 .mov, and joining the MTS files for editing in Final Cut Pro X.
After converting and merging the MTS files, just import the output files to Final Cut Pro X and the video is in HD 1920×1080. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
Read More :
Blu-ray Player Software for Windows 7/8/8.1 Review : UFUSoft Blu-ray Player
LaCie Hard Drive Data Recovery,Recover Files from LaCie Hard Drive
Recover Panasonic HPX170/HVX200 P2 Card Deleted, Formatted or Lost Files
Mac OS X Mountain Lion File/Data Recovery Software
How to Play Protected Blu ray Folders on Mac OS X?
Easy Solution to Get Your Windows 7 Play Blu-ray Movies or ISO Files
Blu-ray Video/Media Player Software for Windows 7/8/8.1/Vista
Convert JVC GC-PX100 AVCHD files to AIC for iMovie 11/09/08 on Mac
Transcode/Convert AVCHD files to AVI for Editing in Pinnacle Studio
martylyy
Postova:  26
Pridružio se:  10.04.2014 8:06
