Editing Android videos in FCP/iMovie/FCE smoothly
Postod lauralily520 » 10.08.2015 9:58
"Why won't the videos from my Android phone import into imovie? It reads that they exist on my Macbook, an imovie gives me the option to import them, however, nothing pops up after I select them."
After recording videos on Android devices, the first challenge is to get the files work with NLEs on Mac OS X. This article will teach you how to edit Android videos in FCP, iMovie, FCE or other NLEs on Mac.
In general, the video shot by Android phone is in 3gp or mp4 format, while both of which are not compatible with FCP/iMovie/FCE. To achieve the goal, you’d better encode Android file into FCP, iMovie, FCE friendly codec with a powerful App. Here Brorsoft Video Converter for Mac is highly recommended. With it, users can effortlessly encode Android videos to FCP, iMovie,FCE friendly codec like Apple ProRes and AIC. In addition, it also offers optimized codecs for other NLEs, including DNxHD for Avid, MPEG-2 for Premiere and more. Now download the software on mac and follow the guide below to start conversion.
Free Download Android Converter on Mac:
Slika (Note: Click here for OS X 10.5)
Tutorial: How to Open Android videos in FCP, iMovie, FCE timeline
Step 1: Load Android video files
Run the best Android video Converter on Mac and click Add button to load them for conversion. You can check the "Merge into one" box to join several files together.
Step 2: Choose a format for FCP, iMoive, FCE
Click "Format" drop-down bar to select a proper video format. "iMovie and Final Cut Express > Apple Intermediate Codec(AIC) (*.mov)" is the best compatible video format you need for editing Android videos in iMovie/FCE. And for Final Cut Pro, Final Cut Pro >> Apple ProRes 422 is optimal.
Step 3: Set proper video/ audio parameters
Click the "Settings" button and set proper video/ audio parameters. You can reset set the video size, bitrate and frame rate, audio sample rate, audio channel. If you would like to use default settings, simply skip this step.
Step 4: Start Conversion on Mac
When you finish all settings, click the "Convert" button to start the Android video to FCP, iMovie, FCE conversion. After the conversion, you can click "Open" button to get the generated Android files effortlessly. Now, it's much easier for you to add Android video files to FCP, iMovie, FCE for further editing.
More Topics:
Can I edit MOV files in Edius smoothly ?
Playback DVD videos on Nokia NI easily
Fast resolve Nikon S9900 to FCP/iMovie importing issues
Best software to encode XDCAM to Apple ProRes on Mac
How to Make Sony FDR-AX33 XAVC S files work with Avid
Make MTS/M2TS videos editable in Cyberlink PowerDirector
Convert Canon PowerShot SX710 HS H.264 MP4 to AVI for Pinnacle
Transcoding Panasonic Lumix GX8 footage to FCP, Premiere Pro, Avid
Convert XDCAM video to ProRes(422, 422 HQ, 422 LT, 4444) for FCP
Editing Canon PowerShot SX710 HS clips in Premiere Pro CS5/CS6/CC
Source: Transfer Android videos to FCP/iMovie/FCE for editing
lauralily520
Postova:  150
