DVD Ripper for Windows 10 - Rip DVDs on Windows 10
Postod lauralily520 » 07.08.2015 9:44
Summary: Looking for DVD ripper that is compatible with Windows 10 so that you can rip DVD in Windows 10 with the best quality? Simply follow this article to get it done!
If you’ve upgraded your PC to the latest Windows 10, you’ll be bothered by the DVD playback and DVD ripping issue. As you see, many guys like you complained that the DVD ripping programs do not work in Windows 10 any more. If you want to convert and watch your DVD movies without any hassles, you need to look for a DVD ripper that is fully compatible with Windows 10. Look no further! You’ve come to the right place. Here I’ll introduce you one of the best DVD Ripper for Windows 10. Just read on!
A litter searching, there are a lot of DVD ripping software turn up on the market. Which Windows 10 DVD ripper is the best? You must use a combination for exactly output formats, quality, encoding speed you want. The most important is that it should be constantly updated to fit with the latest technology that can fully compatible with Windows 10. Like the free app Handbrake only supports Windows Vista/XP/8; it can't work on Windows 10. Overall, Brorsoft DVD Ripper is the best DVD ripper for Windows 10.
This DVD ripping software is especially designed for ripping copy-protected DVDs to MP4, WMV, AVI, MOV, MPEG, FLV, etc on Windows 10 as well as Windows XP/Vista/7/8. In consideration of ease at use, conversion speed and output quality, Brorsoft DVD Ripper is absolutely the outstanding. In addition, it allows you to customize settings to trim, crop, adjust effects, add subtitles for DVD video or adjust parameters (bit rate, frame rate, resolution, codec and more). With this best DVD ripping software for Windows 10, you can also copy DVD to hard drive with two options: Full Disc Backup or Main Movie Copy as you like. Download the program and learn the step-by-step guide on ripping DVDs on Windows 10.
Guide: How to Rip and Convert DVD on Windows 10
Step 1. Load DVD movie
Insert a source DVD in the DVD drive. Install and launch the excellent Windows 10 DVD Ripper, click disc button to load DVD movies. As you see, DVD disc, ISO, IFO and DVD folder are also supported. You can select subtitles and audio track (English, French, German, Spanish...) for each chapter.
Step 2. Set output format
Click on "Format" bar to select output format. Here you can choose rip DVD to .wmv, mpeg-4, mpeg-2, mpg, flv, avi, mkv, etc on Windows 10.
Tips: More features of the versatile Windows 10 DVD Ripper
a. Before conversion, you can go to the “Settings” to set the parameters for your movie. To compress the file size, adjust the parameters to be smaller.
b. You can choose the subtitles which you want to keep. Just click the drop down menu after “Subtitles” to select your desired one.
c. Click Edit button and you can trim, crop or adjust the video with the built-in video editor to get the very part and effect of the DVD movie you want.
Step 3. Start converting DVD on Windows 10
Click "Convert" button to start DVD conversion on Windows 10. After conversion, click "Open" to find the converted movies for playing, organizing, streaming and sharing.
Related Guides:
Transocde AVCHD MTS to EDIUS for editing
Finish DJI Phantom 3 4k to 1080p Conversion
How to Rip and Copy DVDs in Windows 10 Easily
Freemake Video Converter Alternative for Mac OS X
How to Encode DVDs into MP4 for Nokia N1 playback
Directly Scan your iPhone/iPad/iPod Touch to Recover Lost
Importing MTS AVCHD files to EDIUS for editing smoothly
Ripping Blu-ray/DVD movies to Fire Phoneon Mac OS/Windows
Source: Guide: How to Rip and Convert DVD on Windows 10
lauralily520
Postova:  150
