Importing MXF files into DaVinci Resolve 10/11/12
Postod lauralily520 » 19.06.2015 10:23
Summary: This article shows you how to transcode MXF files to DaVinci Resolve compatible format, so that you can play, edit, your MXF recordings on DaVinci Resolve without issues.
MXF files are often produced by high-end cameras and camcorders, like Sony XDCAM, Panasonic P2, and Canon XF to store video, audio, and programmed data. However, MXF as a container format, still can not be supported well by many video editing programs like Davinci Resolve. In this article, we will look at a typical MXF to DaVinci Resolve issue and provide the solution to it as well.
Q: “I have a few .MXF files that I am trying to edit the MXF in Resolve, but DaVinci won't import the MXF files... it says they are missing even though I've selected the right folder. Any way help me out?”
Actually, DaVinci Resolve supports MXF files in theory. But things are different when we import MXF to Davinci Resolve for editing: DaVinci won't import the MXF files... That’s probably because MXF is a relatively complicated format to handle. The best way to let DaVinci Resolve work with MXF clips is to convert MXF files to Davinci Resolve most compatible format like DNxHD. And to finish the task, Brorsoft MXF Converter for Mac is just the best choice.
Overall, it is an easy-to-use yet powerful high-quality MXF converter, player and editor. This software can deal with almost all kinds of MXF videos on Mac OS X. With it, users can effortlessly transcode (P2) MXF files for smoothly editing in DaVinci Resolve. What's more, it can generates more optimal editing formats/codecs for you to use in different NLE apps, such as Final Cut Pro, Avid Media Composer, iMovie, Adobe Premiere Pro, and more. For Windows users, please get MXF Converter. Below is how. Just take a look at the brief guide below.
Guide: Convert MXF videos to DaVinci Resolve acceptable format
1. Import MXF files
Run the Mac MXF Coverer; click the Add button to load .mxf files to the program from your computer or camcorder. You can also directly drag the video files into the program directly.
2. Choose output format
Click Format preset and choose Avid Media Composer -> Avid DNxHD (*.mov)” as the best video format for editing Sony XAVC in Avid as well as good video quality.
Tip: If you like, adjust video and audio parameters, including the Bitrate of Video and Audio, the Codec of Video and Audio, Video Size, Sample Rate, Frame Rate, Audio Channels, etc., by clicking the Settings button on the main interface for getting the best quality.
3. Start conversion
Hit "Convert" button to start MXF to DNxHD .mov conversion for Davinci Resolve. You can follow the conversion process from the pop-up windows.
After the conversion, you can import the converted MXF files to Davinci Resolve 10/11/12 for smooth playback and editing. No more worries about the MXF incompatibility with DaVinci Resolve.
Additional Tips:
The versatile MXF to DaVinci Resolve converter is not only designed for converting MXF files for Resolve. It is also professional in making Canon, Sony, Panoramic MXF files editable in Adobe Premiere Pro, Final Cut Pro, Avid Media Composer, After Effects, iMovie, etc to meet your different needs.
Related posts:
Transfer ProRes to MP4 for Mac OS X (Yosmite)
How to convert VOB for Windows Movie Maker
Encode AVI videos to AIC .mov for iMovie editing
How to convert videos on Windows 8.1 fast and easily
Guide: How to convert and import AVI files to iMovie
Guide for Converting Video on Windows 8.1 with ease
Editing Panasonic HC-X920 AVCHD in FCP 7, FCP X
How to rip Blu-ray/DVD movies to Oneplus One/Two in clicks
Transfer VOB files to WMV for importing to Windows Movie Maker
Getting Sony A7R II Media (4K XAVC S/AVCHD/MP4) into FCP 7/X
Source: How to convert and import MXF files to Davinci Resolve
lauralily520
Postova:  150
Re: Importing MXF files into DaVinci Resolve 10/11/12
Postod Andyeric » 24.06.2015 8:56
Log & Transfer Canon C500 MXF to Final Cut Pro 6 for editing on Mac
Summary: Trouble importing C500 MXF into Final Cut Pro 6? Is there a way I can import Canon C500 MXF files into FCP 6 for editing without rendering? With this awesome guide, you can smoothly import and edit MXF files in FCP 6 by transcoding MXF to Apple ProRes on Mac.
Hot Search: MXF Column | FCP Column | MXF to FCP X | MXF to Premiere Pro CC | MXF to MPEG-4 | MXF to Sony Vegas | MXF to QT/ WMP/Playback Pro | MXF to TV
Canon EOS C500 4K Digital Cinema Camera offers a Super 35mm, 8.85-megapixel CMOS image sensor, DIGIC DV III Image Processor and an expansive range of recording and output options specifically for 4K and 2K image acquisition. It can record super high resolution (4096×2160 pixels) videos in MXF format which are seldom seen in the market. Other resolutions such as 2048*1080 and 1920*1080 are also selectable with this C500.
I tried to import my C500 clips to FCP 6 with L&T and I met the "The files are unsupported" message in L&G window. I searched many information to look for the reason and solve the importing problem, but I failed. Many users said that it was likely to be the system. So I have to start to look for a third party converter to convert C500 MXF. to FCP 6 on Mac OS X.
As we know, MXF format is not a common video format like AVI, MKV, MP4, and it is not supported by FCP 6 on Mac. Below is a guide for you to convert C500 MXF to FCP 6 with Apple ProRes 422 codec, then you can log and transfer C500 MXF in FCP 6 for editing smoothly.
Pavutbe MXF Converter for Mac is the best MXF to FCP Converter I have tried out in the past few months. Very simple, no headaches, no worries, no plugins and no need for any unnecessary steps. The most important is that the converted quality is perfect for viewing and editing. (Read also Best MXF Converter for Mac Review)
Slika Slika
- Pavtube old official address: http://www.pavtube.com/mxf-converter-mac/
- AppStore Download: https://itunes.apple.com/us/app/pavtube-mxf-converter/id502807634?mt=12
- Amazon Download: http://www.amazon.com/Pavtube-MXF-Converter-Mac-Download/dp/B00QID8K28
- Cnet Download: http://download.cnet.com/Pavtube-MXF-Converter/3000-2194_4-76177789.html
Bellow are the simple steps:
Step 1. Run Pavtube Canon C500 Mac MXF Converter for FCP, click "Add Video" button to load your MXF files directly from your EOS C500 camera, or from a CF card reader, or from the file folder that contains the source MXF videos stored on your computer's hard disk drive.
Step 2. Select "Apple ProRes 422 (*.mov)" as target format for Final Cut Pro (X) under "Final Cut Pro" option. it's the best format for editing Canon C500 MXF in Final Cut Pro 6.
Note: If you want output the compatible ProRes MOV file with all the audio tracks retained, Pavtube iMixMXF is the best multi-track software.
Step 3. Adjust video and audio parameters. (Optional)
Click "Settings" button to customize the output video and audio settings by yourself. But if you are not good at it, you'd better use the default parameters, they will ensure you a good balance between file size and image quality basically. You can change the resolution, bitrate, frame rate as you need.
Step 4. When above steps finished, you can click "Convert" button to start converting Canon C500 .MXF shootings to ProRes 422 for FCP 6 editing. Once the MXF transcoding finished, click "Open" button to get the generated ProRes files.
After conversion, launch Final Cut Pro 6, choose File > Import > Files…, and browse to where you saved the converted MXF clips with multiple audio tracks to. Choose the files that you'd like to add.
Now you are free to log and transfer Canon C500 MXF to Final Cut Pro 6 for smoothly editing.
Good News: Never miss to get Saving up to $44.1, MXF/MTS/M2TS/MKV/FLV/MOV Converter.etc at Pavtube Bundles Deals
See related soultions for MXF video:
Top 4 Best MXF Converter for Mac Review 2015
Can FCP X Accept Avid MXF Files on Mac?
Edit Sony PMW-500 MXF Videos to Broadcast in BBC's ‘Jupiter
Import Sony XDCAM PXW-X180 XAVC/MXF in Final Cut Pro X
Import PXW-X70 XAVC 50Mbps MXF to Sony Vegas Pro 12
Import Sony F65 Raw MXF Clips to FCP X on Mac
Transcode MXF to AVI Easily and without Quality Drop
Transcode MXF to MP4 on Windows and Mac
Play MXF with QuickTime Player on Mac
Edit Ikegami MXF Files in iMovie/FCE
Canon XF300 MXF Read Errors in Premiere Pro CC
Convert P2 MXF/MXF to MOV, MP4, AVI, WMV, MKV, ASF, SWF
Source:
Log and Transfer C500 mxf TO fcp 6
