How to import Panasonic AG-HVX200 P2 MXF file to Premiere Pr
Postod Andyeric » 26.03.2015 8:38
Best Panasonic HVX200A P2 MXF to Premiere Pro Workflow
Superb HD video, a raft of frame-rate choices, support solid-state P2 media as well as tape, terrific and relatively wide-angle lens are all advantages of Panasonic HVX200A camcorder.
"I'm still working in standard definition. During the next couple of months, I hope to 'upgrade' to high definition. There are so many choices of cameras. However, I'm most familiar with Canon's GL2 and Panasonic's AG-DVX100B (on the SD side). So, I'm thinking about purchasing an HD camera from either Canon or Panasonic that's comparable to what I have on the SD side. For Panasonic, it would be AG-HVX200A HD camera. It still uses tape, but it can also use its P2 card."
So, for anyone who has used the HVX200A camera, how do you like it? And how do you solve editing Panasonic HVX200A P2 MXF in Premiere Pro CS6 troubles? It's really a big boost that Adobe Premiere Pro CS5, CS6 offers much better native MXF support than its predecessor. However, different source files work differently in Premiere Pro. Many MXF to Adobe Premiere Pro issues still exist there and troubled the users. To achieve your goal to edit MXF clips with Premiere Pro CS6 without problems, we recommend the easy-to-use yet professional application Pavtube MXF Converter for Mac.
Tips: Adobe Premiere Pro supported formats
How to edit Panasonic HVX200A P2 MXF files in Premiere Pro CS6?
Step 1: Install and launch HVX200A P2 MXF Mac Converter, and then click "Add video" button to load HVX200A P2 MXF files or directly drag the footage to the program.
Step 2: Choose output format. This video converter offers optimized format preset for Adobe Premiere. Just click "Format" menu firstly and then follow "Adobe Premiere/Sony Vegas" to set MPEG-2 (*.mpg) format.
Step 3: If the default settings do not fit you requirement, you can click "Settings" icon to and enter "Profile Settings" panel to adjust video size, bit rate, frame rate, sample rate and audio channels.
Step 4: Finally hit the "Convert" button; the best Mac MXF Converter will convert Panasonic HVX200A P2 MXF files to MPEG-2 .mpg for Adobe Premiere Pro CS6 immediately.
Conclusion: When the conversion process shows in 100%, you can get the generated videos from output folder easily for easier editing in Premier Pro CS6.
Further Reading:
Source: http://cameraworld.skyrock.com/3246203294-Panasonic-HVX200A-P2-MXF-to-Premiere-Pro-CS6-Troubles.html
