How to Import 60p AVCHD MTS footage to Sony Vegas Pro
Postod Andyeric » 14.01.2015 10:11
Summary: Have issues with importing 60p AVCHD MTS footage to Sony Vegas Pro on your Windows 8.1 or 8? Just follow the steps below to convert 60p MTS to Sony Vegas Pro compatible format(MPEG-2 format) to sovle it.
Nowadays, more and more cameras and camcorders can give high-definition 1080 60p shootings. But we usually meet the problems while importing the 1080 60p AVCHD to Sony Vegas Pro (latest version 13 included) for postproduction.
See also: Top 5 Video Editors Review - It is never hard for you to edit mts or m2ts files!
Why does this happens? The reason behind that you can't edit 60p AVCHD MTS files in Sony Vegas Pro smoothly is due to the format and codec. AVCHD MTS is a delivery codec rather than editing codec and the 1080 60p is a non-standard format for NLE such as Sony Vegas Pro.
It is really bad news for Windows users. Is there any good way to make it though? Since Sony Vegas will not load 60p mts files directly, perhaps we can do it with the help of third-party software which helps to these 60p AVCHD clips to Sony Vegas Pro supported video formats like WMV format, making it possible for us to edit the 60p mts videos in Sony Vegas Pro smoothly.
Among so much software on the market, it is strongly suggested using Pavtube 60p AVCHD Video Converter. I tried the trial and it worked so i bought it right away I have no complain, the program works fine in 60p mts to wmv conversion for editing in Sony Vegas Pro. Moreover, it allows you to do simple editing to the videos such as cropping, altering video dimension, adding special effect, and adjusting video or audio parameters like Video Resolution/Frame Rate or Audio Sample Rate freely as you like. It has never disappointed any users in due to its splendid performance and easy-to-use operation which goes as below:
(P.S. If you only want to deal with AVCHD MTS footages on Windows Editors: Sony Vegas, Avid Media Composer, Adobe Premiere, Windows Movie Maker and Pinnacle Studio, etc, just try Pavtube MTS/M2TS Converter)
Firstly, download and install this converter.
Step 1. Click "Add" to load 60p mts video files or directly drag the files into file list.
Step 2. Click "Format" bar to determine output format. For smoothly editing in Vegas, you are recommended to choose Adobe Premiere/Sony Vegas -> WMV (VC-1) (*.wmv), this format is best for Sony Vegas Pro editing.
Step 3. If you would like to customize the video and audio parameters, you can click "settings", adjust the parameters as you want, like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels. (Optional)
Step 4. Click "Convert" to start to convert 60p MTS to Sony Vegas Pro.
With this MTS to Vegas Converter, it becomes easy for you to convert your 60p mts video to Sony Vegas Pro smoothly for editing.
Related articles:
  • MTS/M2TS Converter for Mac($29) + MXF Converter for Mac($29) = Only $29.9
  • MTS/M2TS Converter for Mac($29) + MKV Converter for Mac($29) = Only $29.9
  • MTS/M2TS Converter for Mac($29) + FLV/F4V Converter for Mac($29) = Only $29.9
  • iMixMXF($45) + HD Video Converter for Mac($35) = Only $54.9 .....
Source: http://handycameratips.jimdo.com/2013/12/28/sony-vegas-workflow-with-mts-files/
