ProRes HQ 422
ProRes HQ 422
Postod bojan031 » 11.02.2016 22:40
Poz ekipa,nije me odavno bilo... dobio sam je jedan fajl za obradu, radim iz premier-a, pa me interesuje koliko je on 'težak' za obradu, to jest da li mu treba jaka mašina (meni se čini, da treba) i da li ste se susretali sa ovom vrstom snimaka i ako jeste kakva su iskustva, konkretno, da li secka premier,gube li se frejmovi prilikom reprodukcije i tome sl?
Complete name : E:\SC 2014\mov\MIX1.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 0000.00 (qt )
File size : 141 GiB
Duration : 1h 2mn
Overall bit rate : 325 Mbps
Encoded date : UTC 2015-06-26 14:01:26
Tagged date : UTC 2015-07-06 20:50:35
Writing library : Apple QuickTime
©TSC : 5000
©TSZ : 100
Format : ProRes
Format version : Version 0
Format profile : 422 HQ
Codec ID : apch
Duration : 1h 2mn
Bit rate mode : Variable
Bit rate : 323 Mbps
Frame rate mode : Constant
Frame rate : 50.000 fps
Chroma subsampling : 4:2:2
Bits/(Pixel*Frame) : 3.112
Stream size : 140 GiB (99%)
Title : Core Media Video
Tagged date : UTC 2015-06-26 15:04:59
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : lpcm
Duration : 1h 2mn
Bit rate : 2 304 Kbps
Bit depth : 24 bits
Stream size : 1.00 GiB (1%)
Title : Core Media Audio
Other
Type : Time code
Format : QuickTime TC
Duration : 1h 2mn
Time code of first frame : 00:00:00:00
Time code, striped : Yes
Title : Core Media Time Code
Bit rate mode : CBR
bojan031
Postova:  14
Pridružio se:  01.12.2012 13:57
Re: ProRes HQ 422
Postod tipper900 » 07.12.2017 10:27
Hi, Adobe Primere supports MPEG-2 best, you need to convert ProRes HQ 422 for Premiere
tipper900
Postova:  4
Pridružio se:  07.12.2017 10:18
