Ono sto ste mi savetovali sam pokusao vec neznam koliko puta medjutim uvek je ton nesinhronizovan tako da na pocetku ima malo kasnjenje a pri kraju kasnjenje je oko 7 sekundi .
Evo i media info za oba videa.
Drugu metodu nemogu da koristim posto su oba mp4 materijaal a navedeni program neprepoznaje mp4 .
Kraja ocito nema, kao ni crtanog odlicnog kvaliteta slike i srpskog tona za moje klince .
Evo ovo su media info posle mkv gui prebacivanja drugog file u brzinu 23.976 kao sto ima prvi file.
1. mp4 video odlican , audio nepotreban (eng)
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 220 MiB
Duration : 22mn 2s
Overall bit rate : 1 392 Kbps
Format profile : High@L3.1
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 22mn 2s
Bit rate : 1 198 Kbps
Maximum bit rate : 9 643 Kbps
Width : 1 280 pixels
Height : 720 pixels
Frame rate mode : Constant
Bits/(Pixel*Frame) : 0.054
Stream size : 189 MiB (86%)
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 22mn 2s
Bit rate mode : Variable
Bit rate : 192 Kbps
Maximum bit rate : 202 Kbps
Sampling rate : 44.1 KHz
Stream size : 30.3 MiB (14%)
2.mp4 video los ali potreban srpski audio
Format : Matroska
Format version : Version 4 / Version 2
File size : 174 MiB
Duration : 22mn 9s
Overall bit rate : 1 100 Kbps
Encoded date : UTC 2014-11-10 09:13:58
Writing application : mkvmerge v6.6.0 ('The Edge Of The In Between') built on Dec 1 2013 17:55:00
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Format profile : Baseline@L1.3
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : N=1
Codec ID : V_MPEG4/ISO/AVC
Duration : 22mn 9s
Bit rate : 950 Kbps
Nominal bit rate : 1 024 Kbps
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Bits/(Pixel*Frame) : 0.096
Stream size : 151 MiB (86%)
Writing library : x264 core 119
Encoding settings : cabac=0 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=1024 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Duration : 22mn 9s
Bit rate : 128 Kbps
Stream size : 20.3 MiB (12%)
Default : Yes
Forced : No
