DVD ne cita sve filmove
Postod Gost » 05.03.2014 23:05
Pozdrav,
na dvd-u ne mogu da pustim sve filmove na koje nalepim prevod preko virtual dub-a.
Neki uopste nece da se puste(uglavnom BRRip,H624) i to razume,stari dvd,jeftin....Ali neke ucita,ide zvuk ali slika izgleda ovako,sve vreme:
Info1:
Complete name : C:\Users\win7\Videos\FILMOVI\NE RADI NA DVD\PREVOD\A.Fistful.of.Dollars.1964.640.25fps.911kbps.V5.WunSeeDee\A.Fistful.of.Dollars.1964.640.25fps.911kbps.V5.WunSeeDee.avi
Format : AVI
File size : 465 MiB
Duration : 1h 35mn
Overall bit rate : 677 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDub build 32839/release
Format : MPEG-4 Visual
Format profile : AdvancedSimple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 35mn
Bit rate : 572 Kbps
Width : 640 pixels
Height : 272 pixels
Display aspect ratio : 2.35:1
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.131
Stream size : 393 MiB (84%)
Writing library : XviD 64
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format_Settings_Mode : Joint stereo / MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 35mn
Bit rate mode : Variable
Bit rate : 92.4 Kbps
Minimum bit rate : 32.0 Kbps
Resolution : 16 bits
Stream size : 63.4 MiB (14%)
Interleave, duration : 24 ms (0.60 video frame)
Interleave, preload duration : 199 ms
Writing library : LAME3.97b
Encoding settings : -m j -V 5 -q 3 --vbr-new -b 32
Info2:
Complete name : C:\Users\win7\Desktop\Ne valja slika\Hostel (2005).avi
Format : AVI
File size : 345 MiB
Duration : 1h 29mn
Overall bit rate : 539 Kbps
Writing application : VirtualDubMod 1.5.10.1 (build 2366/release)
Codec ID : XVID
Duration : 1h 29mn
Bit rate : 337 Kbps
Width : 576 pixels
Height : 240 pixels
Display aspect ratio : 2.40:1
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.098
Stream size : 216 MiB (63%)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 1h 29mn
Bit rate : 192 Kbps
Channel positions : L R
Stream size : 123 MiB (36%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Info3:Na ovom cak nema nikakva slika,samo zvuk
Complete name : C:\Users\win7\Desktop\Nema slike zvuk radi\Mclintock [1963].avi
Format : AVI
File size : 1 018 MiB
Duration : 2h 2mn
Overall bit rate : 1 165 Kbps
Codec ID : XVID
Duration : 2h 2mn
Bit rate : 900 Kbps
Width : 720 pixels
Height : 312 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.160
Stream size : 786 MiB (77%)
Format : MPEG Audio
Codec ID : 55
Codec ID/Hint : MP3
Duration : 2h 2mn
Bit rate : 256 Kbps
Stream size : 224 MiB (22%)
Writing library : LAME3.98.4
Zna li neko razlog???
Gost
Re: DVD ne cita sve filmove
Postod Video Majstor » 06.03.2014 1:14
Pozdrav, :)
Hmmm... parametri deluju da su ok. Evo šta je potencijalno problematično:
Ovo znači da se koriste B frejmovi ali ne znam koliko. Važeno je koliko B frejmova uzstopno podržava tvoj DVD plejer. Radi kompatibilnosti najbolje je podesiti da se koristi samo po jedan B frejm što je u okviru "DivX Home Theater" profila. Ima u našem vodiču za podešavanje XviD codeca objašnjeno gde se ovo podešava i šta preporučujemo.
http://www.videomajstor.com/encoder-xvid
Ne znam koji si enkoder koristio?
Preporučujem "Koepi's XviD Codec v1.3.2" kao u našem vodiču.
Možeš da ga skineš odavde na primer: http://www.free-codecs.com/download/koepi_xvid.htm
Takođe ne zaboravi da pre svega u XviD-u odabereš dobar preset jer će te on sprečiti da prekoračiš neke parametre.
Za kučni DVD trebaš izabrati "Advanced Simple @Level 5" kao na slici.
Da li se ta slika pomera ili ostaje tako zamrznuta?
- Probaj da odradiš jedan sa istim podešavanjima koje sam predložio ali bez lepljenja subtitla. Jer postoji mogućnost da je taj filter za subtitle iz nekog razloga loš i da je upropastio sliku.
A ako ne pomogne ovaj moj post nikako vrlo je moguće i da je taj DVD jednostavno veoma loš u čitanju divx-a...
I obavezno se drži ovih naših preporuka: http://www.videomajstor.com/saveti
Postod Gost » 06.03.2014 2:58
Hvala.Sutra ili prekosutra cu ovo odraditi,pa cim budem zavrsila javicu rezultate. :heart: :give_rose: :agree: :)
Gost
Postod Gost » 06.03.2014 3:31
Evo primera koji rade,a sve sam na isti nacin sredila,u virtual dub-u ubacim titl,pa compresujem sa Xvid MPEG4 Codecom.(isprobacu i ovaj sto si mi preporucio)
1.
Complete name : C:\Users\win7\Desktop\The.Conjuring.2013.BRRip.XviD.AC3-BS5\The.Conjuring.2013.avi
Format : AVI
File size : 843 MiB
Duration : 1h 51mn
Overall bit rate : 1 052 Kbps
Codec ID : XVID
Duration : 1h 51mn
Bit rate : 659 Kbps
Width : 720 pixels
Height : 304 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.126
Stream size : 528 MiB (63%)
Writing library : XviD 1.3.0.dev55
Format : AC-3
Codec ID : 2000
Duration : 1h 51mn
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Stream size : 307 MiB (36%)
Interleave, duration : 42 ms (1.00 video frame)
2.
Complete name : C:\Users\win7\Desktop\The.East.2013.HDRip.XviD-S4A\The east 2013.avi
Format : AVI
File size : 457 MiB
Duration : 1h 56mn
Overall bit rate : 550 Kbps
Codec ID : XVID
Duration : 1h 56mn
Bit rate : 413 Kbps
Width : 640 pixels
Height : 272 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.099
Stream size : 343 MiB (75%)
Format : MPEG Audio
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 56mn
Bit rate : 128 Kbps
Stream size : 106 MiB (23%)
Gost
Postod prijateljv » 06.03.2014 11:22
ajde ovako...
- za pocetak napisi tacan model tog DVD-a da pogledamo njegove "generalije"
- da li filmove rezes na CD-DVD ili pustas preko flas-a ?
- DVD (uglavnom) izbaci "unsupported video (ili audio) format" kada mu nesto "nije leglo" ali onda nema nikakve reprodukcije
- ta "zamrznuta" slika na pojedinim filmovima,pored formata,kodeka i sl.moze da bude uzrok zaprljanog ili dotrajalog lasera - ovo vazi samo ako filmove gledas preko CD-DVD-a...ali...
Probaj da "odseces" parce tog filma iz sredine (5-10 min.) sa Virtual Dub: znaci i audio i video "direct stream copy" pa probaj...nekada se DVD "zabuni" zbog "audio delay (ms)...a mozes i takvom filmu (za probu) da "izvadis" audio pa da probas...
Moja preporuka je koriscenje XviD (1.2.1) kodeka : http://www.doom9.org/
Virtual Dub "jednostavno nema konkurenciju" ali za probu mozda probati i drugi program - MeGUI - sa kojim pored kvalitetnog kompatibilnog AVI (XviD) konvertovanja takodje mozes da lepis titl...
jos neke informacije...
- da li ti samo pojedini filmovi koje si ti konvertovala sa Virtual Dub prave problem ili...?
- da li lepis titlove zbog malog prikaza...mozda probati "AVIAddXSub914" ako tvoj DVD podrzava DivX (XSUB,Idx/Sub) gde se sve ovo odradi za 30...60 sec. bez konvertovanja,pozz...
Postod Video Majstor » 06.03.2014 22:39
Vrlo moguće da je problem u enkoderu koji si koristila uz VirtualDub.
Ovaj je u svim primerima koji ne rade.
A ovaj je u svim primerima koji rade.
Dakle, pre svega preporučujem da instaliraš jedan od (u ovoj temi) preporučenih XviD enkodera. I ostale stvari su bitne ali ovo mi deluje najupadljivije da prvo probaš.
Ne znam da li ima neki razlog za baš tu verziju. Ta je dosta stara. Koepi's XviD Codec v1.3.2 za kojeg je i napisan vocič sa sajta je nekoliko verzija noviji i do sada je skroz proveren.
Gost je napisao:Hvala.Sutra ili prekosutra cu ovo odraditi,pa cim budem zavrsila javicu rezultate. :heart: :give_rose: :agree: :)
Postod Gost » 10.03.2014 2:44
Tek danas sam imala vremena da se pozabavim vasim preporukama.Sad uglavnom sve radi,ali to je i dalje prava lutrija.Isprobam prvo sa menjanjem BVOP-a sa 2 na 1,radi,vratim na 2,radi opet.
Isprobam ove kodeke koje ste preporucili(tj. one koje je virtual dub ucitao) i jos neke Xvid i divX i sve radi.
@VideoMajstor,nisam uspela da isprobam sve sa slicica koje si postavio,jer program ne dozvoljava izabiranje nekih opcija.Takodje sam procitala ove preporuke http://www.videomajstor.com/saveti pa sam se njima upravljala u slucajevima gde je divX format.
@prijateljv rezem na dvd,jer ovaj dvd nema usb ulaz,kad sam kuci onda na usb.Inace dvd je lg DVX162,i kupljen pre 100 god.Lepim prevod iz dosade,i jer ova kanta ne cita svaki put srt,a i kad pozajmis nekom da ne mislis...Samo neki filmovi prave problem,i to iz do sad jos uvek nepoznatog razloga. :dash2: Kao sto je i potpuno sumanuto da ceo film sa zalepljenim prevodom radi,a da 5 min iz sredine ne radi. :shok:
Tako da momci,hvala vam puno.Misterija ostaje. :flag_of_truce:
Istina je negde tamo. ;)
:hi: :heart:
I da,izvinite ako su vam moja pitanja bila smesna. :sorry:
Gost
Postod Video Majstor » 12.03.2014 1:19
Evo kompletan vodič za podešavanje
napisan za "Koepi's XviD Codec v1.3.2"
Ako se podešavanja vrše tim redom trebalo bi i da ponuđene opcije budu kao na slikama. ...možda je to u pitanju.
Naravno da nisu. :good:
