How to Undelete Pictures On a Computer
Postod Applezu » 06.11.2012 6:28
Help! I accidentally deleted a picture folder yesterday........and I need to get it back. I emptied it from the recycling bin.
You might have ever deleted some important picture files about your loved ones or lover on your Mac in error. I'm sure you will need to feel regret then. But don’t be now, there still have ways to help you undelete pictures . Any deleted picture files on the Mac may be recovered as your hard disk drive will never be physically broken. Actually, all the picture files remain kept in your hard disk drive.
Here I will show how to undelete pictures
Step A. Download software from the internet and install on your computer.
Step B. Connect your card with the computer. Open the installed software.
Step C. Select the way you need to recover photos, " Deleted Recovery" or " Format Recovery" .
Step D. Scan you card, then choose the photos you need, click "Recover".
More
When things happen, immediately stop with your memory card which stored precious pictures, movies as well as other files. If you're much more cautious, plug the memory card from the device like digicam, camcorder, cellular telephone and even gaming console, etc. and set it in safe place. Then you can follow the picture undelete mac method above to get your pictures back!
Applezu
Postova:  14
Pridružio se:  05.10.2012 12:52
Re: How to Undelete Pictures On a Computer
Postod Kimmer1 » 30.08.2014 8:59
If your iPhone data are indeed gone, I would suggest you try using iTunes in order to restore your iPhone data (including sms)from the last time you last synced your iPhone with your iTunes. Here is about how to recover photos from iPhone.
Here are two easy methods to recover data from old iPhone:
One. Recover iPhone Data without Backup by using third party iPhone Data Recovery Software
how to recover deleted text messages from iPhone
Two. Recover data from iPhone via iTunes.
how to recover iPhone contacts
Kimmer1
Postova:  3
Pridružio se:  30.08.2014 6:42
Korisnici koji su trenutno na forumu: Google [Bot] i 14 gostiju
