How to add text to a PDF document using PDF Editor for Mac?
Postod ricky24 » 18.04.2012 7:46
There is no doubt that PDF files are a great way for reading text and viewing graphics. At times, you may have a need to add additional text to a PDF file.
As we know, Mac users can view and annotate PDF files with the built-in application "Preview". But it is not enough if you have other needs like adding text, editing the contents, inserting images, etc. For people who want full editing features on PDF, you can have a try on PDF Editor for Mac.
About PDF Editor for Mac
With the PDF Editor for Mac, you can add text to PDF files easily as you like. The main features of the program are:
1. Add, copy, move and delete text in PDF files directly.
2. Support auto-matching system fonts.
3. Modify PDF properties as you like.
4. Annotate the PDF contents easily
5. Add Bookmark if needed
More Info:
Kod: Obeleži sve
www.pdf-editor-for-mac.com/editor/
Video Guide:
Kod: Obeleži sve
www.youtube.com/pdfconvertermac/
How to add PDF text on Mac
1. Install the PDF Editor for Mac on your computer at first.
2. When you double click the shortcut to launch the program, it will pop up a dialogue asking you to open the PDF files which you want to edit. Or you can click "File -> Open" from menu bar to open the PDF files.
3. Choose "Add Text" tool on the toolbar, and then click a blank area on the page, you can add text in the editable text box directly.
After adding text, click "File -> Save" option from menu bar to save the edited PDF file. If you do not want to overwrite the source PDF file, click "File ->Save as" option instead.
Original:
Kod: Obeleži sve
www.pdf-editor-for-mac.com/tips/how-to-add-text-to-a-pdf-document-mac.php
Related Tags:
pdf editor for mac; edit pdf text mac; pdf text editor; add text to a pdf; adding text to pdf
add bookmarks to pdf; add pages to pdf; insert text into pdf; add annotations to pdf; add notes to pdf
Edit, annotate and convert PDF files on Mac
http://www.youtube.com/watch?v=giTgoUUMDP8
ricky24
Postova:  42
Pridružio se:  14.03.2012 10:42
Re: How to add text to a PDF document using PDF Editor for M
Postod joeronald » 18.09.2012 5:14
PDF Editor Pro for Mac
Simply edit scanned PDF documents with OCR technology
Edit (Add, modify, move, delete) text in PDF documents
Insert/move/copy/crop/resize/delete images within PDF files
Export Word/Excel/PPT/EPUB/HTML/Image/Text/RTF from PDF
Annotate by adding notes, text boxes and graphics to PDF files
Markup PDF with highlighting, underscoring, and strikethrough
Video Demo:
PDF Editor
Edit PDF files exactly like a Word processor
Convert PDF to Word, PowerPoint, Excel and EPUB (Exclusive!)
Edit or convert scanned PDF (Available in OCR plug-in)
Secure your PDF with password protection
Merge, split and extract PDF pages with ease
Easily add comments, notes and more in PDF
Create PDF from Word, PowerPoint, Excel, Text, etc.
joeronald
Postova:  30
Pridružio se:  27.07.2012 5:17
