Best way to Convert WLMP to MP4 Easily on Windows/Mac
This article shows you how to export video from WLMP files and then convert the created video to MP4 video with the best WMLP to MP4 converter easily.
WLMP, short for Windows Live Movie Maker, is a project file saved with Windows Live Movie Maker on Windows 8 or Windows 7. With it, you can easily make family movies from photos, videos, and music. However, you should know that WLMP file is not a video file. Therefore, if you want to play or share your created movie in a WLMP video file, you have to convert WLMP to MP4 first. Now you are in the right place learn how to convert WLMP files to MP4 after exporting to WMV from Windows Movie Maker.
How to convert WLMP to MP4 or Other Formats
To fulfill the task, what you need is a powerful video converter which contains no limitation on the transforming from WMLP output WMV format to MP4 or other formats like MPG, FLV, AVI, MOV, etc.. Dimo Videomate is one of the most powerful WMV video converter available. This software allows you to work on the conversion between virtually any video formats. The supported formats include WMV, AVI, MKV, MOV, MPEG, MP4, FLV, H.265, etc.
What's more, you can make changes to the video by using its video editing functions. You can change the visual effects, adding watermark, cropping, trimming in the list of choices. In additional, this program has a simple interface and its drag-and-drop functionality makes the conversion easier to all users. The users who want to convert WMV files on macOS Sierra, El Capitan, Yosemite can have a try on Dimo Videomate for Mac. Just download this powerful software, follow the guide below and enjoy the thrill of WLMP to MP4 video conversion now!
Free Download Videmate (Win/Mac):
Win Mac
How to Convert Windows Live Movie Maker Files to MP4
Step 1. Export Windows Live Movie Maker files to WMV files
Launch Windows Live Movie Maker, go to "File -> Open project" to import your local Windows Live Movie Maker project files. Click "File" again, and then select "Save movie" > "Standard-definition" to export to WMV format.
Step 2. Add WMV video files to the program
Install and launch this WLMP to MP4 converter, open it, go to "Converter" menu and then click "Add File" button to load your WMV video files you want to convert. Or, you can also directly drag and drop the WMV files into the program. If you want to specify the output folder, just click the three dots beside Open Folder to choose your desired folder.
Step 3. Select MP4 as output Format.
Go to "Format" -> "Video" from "Select Format", select "MP4" as output format. Or choose HD/4K MP4 from "HD Video". The optimized default settings ensure a good balance between WLMP to MP4 conversion speed and quality.
If you are planning to transfer the converted files to your iOS devices like iPad, iPhone or iPod etc. you can choose the presets supplied by the professional Video Converter so that you needn’t set the resolution, frame rate etc. by yourself. And the presets are contained in "Device">"Apple" category.
Note: If you are demanding in high quality, you can adjust parameter settings to improve output video quliaty. The first one is to select codec as "H.264" rather than "MPEG-4", cuz H.264 is known as MPEG-4 Part 10 – Advanced Video Coding (MPEG-4 AVC), providing much higher quality than MPEG-4.
Turn up Frame Rate to 25fps or 30fps to guarantee a sharper image for output video.
Adjust Resolution up, and you can even increase resolution to 4K Ultra HD or 8K Ultra HD based on your original WMV video quality. Certainly, you choose high quality and you will lose comparatively faster speed, for you can’t have cake and eat it.
Step 4. Edit WMV files(optional)
After selecting your preferred WMV file, you can make desired changes by clicking on the Edit icon. When access to the Video Edit panel, you can trim, crop, add watermarks, adjust effect, create 3D, etc. to modify your videos for the best visual effects.
Step 4. Begin Windows Movie Maker .WMV to MP4 conversion
Hit "Convert" and let this smart WLMP to MP4 Video Converter do the rest for you! If your WMV video files is quite large, around 1GB and over 1 hour in length, don’t be worried, the whole WMV to MP4 conversion will not cost your wonderful afternoon time. After the conversion, you'll get resulted videos via "Open" for playback or sharing with high quality.
Additional Tip:
Get Dimo Video Converter Ultimate/Dimo Video Converter Ultimate for Mac with Only $45.95, which can save you $63.9(BDmate $39.95 + Videomate $39.95 + DVDmate $29.95 = $109.85), then you can enjoy any Blu-ray/DVD/ISO or common movies freely on Windows 10/8/8.1/7/Vista/XP.
Related Software:
BDmate (Win/Mac)
Lossless backup Blu-ray to MKV with all audio and subtitle tracks; Rip Blu-ray to multi-track MP4; ConvertBlu-ray to almost all popular video/audio formats and devices; Copy Blu-ray to ISO/M2TS; Share digitized Blu-ray wirelessly.
DVDmate (Win/Mac)
A professional DVD ripping and editing tool with strong ability to remove DVD protection, transcode DVD to any video and audio format, and edit DVD to create personal movie.
8K Player (Win/Mac)
A mixture of free HD/4K video player, music player, Blu-ray/DVD player, video recorder and gif maker.
Free Download or Purchase Videmate:
Contact us or leave a message at Facebook if you have any issues.
Related Articles:
Source: WLMP to MP4: Convert Windows Movie Maker Files to MP4
Win Mac
Additional Tip:
Related Software:
BDmate (Win/Mac)
DVDmate (Win/Mac)
8K Player (Win/Mac)
Related Articles:
- How to Convert QuickTime MOV to MP4 on Windows or Mac Without Hassle?
- Will Windows Media Player play QuickTime MOV? Solved!
- How to Open H.265 Video Files in QuickTime Player
- 2 Methods to Solve can't play MP4 on Windows Media Player
- How to add DVD to Kodi (XBMC) Movie Library for playback
- Top 2017 Movie Torrents
- Can Xbox One S play 4K Blu-ray (disc/folder/ISO)
- Convert Audio from AC3 to AAC in MP4/MKV
- Stream MKV to Chromecast via Plex
- How to Convert WMV to MP3 With the Original Quality
