AVCHD to Edius 6 Workflow -- Edit AVCHD in EDIUS 6
Summary: Stop worrying about format incompatibility issue when importing AVCHD to EDIUS 6. Find out how to convert AVCHD to EDIUS 6.
EDIUS Pro provides a simple alternatives to the industry leaders, but it has all of the tools that other professional video editing software has such as powerful tools, enhanced timeline, advanced multicam support, 64-bit processing. One peculiarity that sets EDIUS Pro apart from others is that it doesn't utilize GPU acceleration for rendering, transcoding and exporting videos. And this is a big advantage over other applications that require time and processing capacity to render footage.
Hot search: MKV to EDIUS Pro 8 | GoPro MP4 to EDIUS Pro 7 | AVI to EDIUS 7/7.01 | Panasonic DVCPro HD MXF to EDIUS Pro 7 | H.265/HEVC to EDIUS 5/6/7/8
"Hello everyone, the past 3 months I tried to collect some money to buy a new camera the Sony a58 which records in AVCHD, long story short I want to know the best project settings and render format in order to edit them in EDIUS 6 and get the best quality out of my videos. Any suggestions about converting AVCHD to EDIUS 6 is appreciated!"
EDIUS Pro supported format for file import:
Since EDIUS lacks GPU acceleration for transcoding AVCHD video files, you will need to employ a third-party application to perform the video codec transcoding process for you. After multiple testing, I found Pavtube Video Converter is the best option. It is able to convert AVCHD to EDIUS 6 friendly format easily with the best video quality. Besides AVCHD, this video convert program can also help to convert between any popular video and audio formats as you need. Plus, with the built-in video editing feature of the program, you can trim, crop, add watermark and more to your video files.
How to import AVCHD to EDIUS 6?
Step 1: As soon as you download and install the program, launch it and when the main interface pops up in front of us, just click the "Add Video" or "Add from Folder" to let in.
Step 2: Click the drop-down list in the format line to get the format box. Then choose "Adobe Premiere/Sony Vegas>>MPEG-2 (*.mpg)" as output format.
Step 4: After that, click "Convert" to start AVCHD to MPEG-2 conversion.
Conclusion: After conversion, you can get the generated files by clicking "Open" button. Now, you’ll get no troubles in editing AVCHD files in EDIUS 6.
More related tips:
Part of Discount Showtime:
Video Win/Mac------------30% off
MTS/M2TS Win/Mac-------20% off
MXF MultiMixer/iMixMXF----20% off
Discount can be found here: http://bit.ly/1hmOn34
Just like us on page and you can get it with all other free software giveaways, useful guides, and lifelong discounts.Enjoy your weekend with favorite Videos on any devices!
Source: http://mts-to-aic-converter.com/edit-avchd-in-edius-6/
More related tips:
- MP4 to EDIUS 6/7/8 Converter--Edit MP4 Video
- Convert Panasonic DVCPro HD MXF to EDIUS Pro 7
- Edit H.265/HEVC in EDIUS 5/6/7/8
- Import AVI File Stuttering/Shaking Problems in EDIUS 7/7.01
- Edit EDIUS AVI Files in FCP X
- Convert MXF to EDIUS Pro 7/8 for Editing
- Import XAVC/XAVC-S to Grass Valley EDIUS Pro 7/8
