Edit MTS/M2TS videos files in Cyberlink PowerDirector
Summary: Wanna transfer MTS/M2TS videos into Cyberlink PowerDirector for editing smoothly? This article will teach you how to make MTS videos editable in Cyberlink PowerDirector.
PowerDirector Ultra provides the most comprehensive and easy-to-use tools for high quality video productions. Users can also sync up to 100 timeline tracks by audio for creating multicam collages. Preserve and share your creative projects with CyberLink Cloud service, and edit videos on-the-go with PowerDirector Mobile. Wanna transfer MTS/M2TS videos into Cyberlink PowerDirector for editing smoothly? This article will discuss how to import MTS/M2TS footage into PowerDirector without any issue.
In fact, if you use latest version of PowerDirector, then it is much easy for you to import MTS/M2TS footage into PowerDirector for further editing. You just need to directly import the original MTS videos from AVCHD disc to the editing software. However, if you are old version user, the MTS editing process will not be smooth in Cyberlink PowerDirector owing to codec problem and computer configuration. Fortunately, there is a simple way for those who plan to edit MTS/M2TS footage into PowerDirector older version-encoding MTS/M2TS format to PowerDirector supported video formats, like AVI, MKV, MP4, MOV, MPEG, VOB, WMV, etc with a powerful video tool: Brorsoft MTS Converter.
It is especially designed for dealing with MTS/M2TS recordings to various professional video editing applications like Cyberlink PowerDirector, Windows Movie Maker, Pinnacle Studio, Sony Vegas, Avid Media Composer, as well as multimedia devices. In addition, this MTS encoder is equipped with some basic editing features including trimming, cropping, adding watermark .ect. to meet your different needs. Just download the program and follow step-by-step guide to convert MTS/M2TS files to work on Cyberlink PowerDirector.
Free Download MTS Converter:
How to Make MTS/M2TS videos editable in Cyberlink PowerDirector
Step 1: Add MTS/M2TS videos
Launch the MTS converter and click "add" button to import the MTS/M2TS files to the program
Tip: If you would like to join all the selected files together, check the box of "Merge into one".
Step 2: Select output format
For encoding MTS to Cyberlink PowerDirector, please click "Format" menu firstly and then follow "Adobe Premiere/Sony Vegas" > " MPEG-2 (*.mpg)". Of course, you can also select other output like AVI , MP4 from "Common Video".
Tip: You can click "Settings" if you’d like to customize advanced audio and video parameters like video Codec, aspect ratio, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels.
Step 3: Start conversion
Click "Convert" to start transcoding the MTS/M2TS recordings to .mpg videos. After conversion, click “Open” to find .mpg videos and for Cyberlink PowerDirector smooth editing.
Read More:
Transocde AVCHD MTS to EDIUS for editing
Finish DJI Phantom 3 4k to 1080p Conversion
Directly recover iPhone iPad iPod touch lost data
How to Rip and Copy DVDs in Windows 10 Easily
Freemake Video Converter Alternative for Mac OS X
Guide: How to Rip and Convert DVD on Windows 10
Transfer Android videos to FCP/iMovie/FCE for editing
How to Make Sony FDR-AX33 XAVC S files work with Avid
Importing MTS AVCHD files to EDIUS for editing smoothly
Convert Canon PowerShot SX710 HS H.264 MP4 to AVI for Pinnacle
Editing Canon PowerShot SX710 HS clips in Premiere Pro CS5/CS6/CC
Transcoding Panasonic Lumix GX8 footage to FCP, Premiere Pro, Avid
Source: Make MTS/M2TS videos editable in Cyberlink PowerDirector
Read More:
