How to Keep 4 Channels Multi-stream MXF to AVI?
AVI is a traditional popular format introduced by Microsoft in 1992. AVI had gained its popularity since it was created. It can contain both audio and video data in a file container that allows synchronous audio-with-video playback. Like the DVD video format, AVI files support multiple streaming audio and video.
Different from AVI format, MXF is like a freshman. It was developing in the decade. In a word, MXF is like a container format for professional digital video and audio media defined by a set of SMPTE standards. It was designed to address plenty of problems with non-professional formats. It has full time code and metadata support which enables it output full HD MXF videos. Multi-track MXF is one kind of MXF formats which is with multiple audio tracks.
MXF and AVI are both well-known video formats in common use. The conversion from MXF to AVI is gradually becoming a hot issue. So how should we keep 4 channels Multi-stream MXF to AVI? I will introduce Pavtube MXF Converter for Mac (Review), a rewarding converter which I had used for one year.
This wonderful multi-track Mac MXF Converter can perfectly convert MXF files with 2, 4, 8 or more audio channels to MP4, AVI, MKV, MOV, ProRes. You don't need to worry about the loss of the sounds any more! Besides the conversion of Multi-track MXF videos, you may also convert MXF files to MKV, MP4, MOV, AVI, WMA, SWF etc. for Final Cut Pro, iMovie, Premiere and countless video editing software and players!
Note: Pavtube MXF Converter for Mac support outputting the original one audio track separately; if you want to combine all the audio tracks, the Pavtube iMixMXF is highly recommended. (Learn more guides)
[b]Following are download and buy button:
- Pavtube old official address: http://www.pavtube.com/mxf-converter-mac/
- AppStore Download: https://itunes.apple.com/us/app/pavtube-mxf-converter/id502807634?mt=12
- Amazon Download: http://www.amazon.com/Pavtube-MXF-Converter-Mac-Download/dp/B00QID8K28
- Cnet Download: http://download.cnet.com/Pavtube-MXF-Converter/3000-2194_4-76177789.html
Step 1. Import Multi-track MXF files.
Start this Mac program, and its clear instruction in the main interface will clearly show you the main function icon.
Tips: I recommend you to load MXF files from your camcorder first. Then you can add these files to the software. This is to keep the stability of importing files and prevent the conversion to break off.
Step 2: Select "AVI" as the output format.
Open the format bar and choose .avi as output format. There is a convenient way that you can search avi in the searching box.
Step 3: Adjust the specific setting.
Check the 4 channels to ensure the output files retaining the multiple audio tracks.
Tips: You may also change the codec, size, bit rate, frame rate, sample rate, and channels of the video and audio for your specific needs.
Step 4: Start the conversion from MXF to AVI.
Click the "Convert" icon to transcode 4 channels multi-stream MXF to AVI. With just a click on "Open output folder", you can locate the export AVI files easily.
Read More Guides
Review: H.265 Converter for Mac OS X El Capitan
How to Convert MOV Files on Mac OS X El Capitan
Best Way to Edit Video Files on Mac OS X El Capitan
Encode MXF to MOV with Original Audio Tracks Preserved
Import Canon C300 Mark II 4K MXF to Premiere Pro CS6/5/4/3
Import Sony PXW-X70 Video Files into FCPX or iMovie
Ingest Panasonic PX270 AVC-LongG MXF to After Effects CC/CS6
Convert MXF files to MKV/VOB/AVI/MOV/MP4/MPEG/WMV/FLV on Windows/Mac
Open Sony PMW-200 XDCAM MXF files in iMovie on Mac
Edit Canon XF105/XF100 MXF Files with Mac iMovie
Solve no audio issue- Convert multi-track MXF files on Mac
Can't open Sony PXW-X70 MXF Videos in Final Cut Pro X
Convert MXF to MKV with multiple audio channels on Windows/Mac
Transcoding Panasonic DVCPRO P2 MXF to AVI/MOV/MPG/WMV for Avid, Sony Vegas, Pinnacle, Cyberlink, Windows Movie Maker
Transcode Blackmagic Design HyperDeck Studio recorder MXF DNxHD (185X) to ProRes for FCP X editing
Tips for Downsizing GoPro Hero 4K Video to 1080p
Source: http://camcordervideoshare.altervista.org/blog/how-to-keep-4-channels-multi-stream-mxf-to-avi/
Read More Guides
