Set the right settings for editing iPhone videos in Premeire
Summary: Encounter problems while importing iPhone videos to Premiere Pro? This article will teach you how to edit iPhone videos in Premiere smoothly.
In order to deal with iPhone videos easily, Adobe has launched a version of its Premiere video editing desktop app for the iPhone and iPad called Adobe Premiere Clip as part of its overall app release plans for the iOS platform. However, if you directly import iPhone videos to Premiere Pro for further editing, you will meet some issues.
"Has anyone had experience editing with native iPhone video footage in Premiere? I've been reading about some people having 'sync slip' issues. Is converting the footage necessary?"
The problem with iPhone footage is it has variable framerate instead of constant framerate, hence the out of sync issue. To edit iPhone Videos in Premiere Pro (CC/CS6) smoothly, the easy workaround is to transcode them to a more editing-friendly format, such as MPEG-2. Brorsoft Video Converter for Mac is what you need, which is the one of the best iPhone video converters for Mac users.
It offers optimized presets MPEG-2, MOV(AVC) for Premiere (CC/CS6/CS5.5/CS5) with maximum editing quality and efficiency. Besides Premiere, it also offers professional codecs for other NLEs, like Apple ProRes to FCP, DNxHD for Avid, AIC for iMovie .etc. If you are a PC user, pls turn to Brorsoft Video Converter Windows version. Now, download the software on computer and follow the guide below to start conversion.
How to Make iPhone videos editable in Premiere Pro
Step 1: Add video files
Click "Add" button on the top of the main interface to load iPhone videos. Or you can simply drag&drop the videos directly to the software.
Step 2: Choose output format
Go to "Format" pull down list to select Adobe Premiere/Sony Vegas> MPEG-2(*.mpg) as the best video format for Premiere Pro. WMV, MOV formats in this column are the good choices as well.
Tip: Click the "Settings" button, you are able to enter the "Profile Settings" panel to adjust video and audio parameters for the converted files, including video size, bit rate, frame rate and more.
Step 3: Start conversion
Tap the Convert button to start transcoding iPhone videos to MPEG-2 for Adobe Premiere Pro.
Once the process completes, you can find the generated videos via "Open" button, then you can transfer the encoded iPhone videos to Premiere without issue.
Related posts:
How to convert AVI to iTunes free on Mac
How to Edit iPhone videos in Premiere Pro?
Importing Blu-ray to Avid Media Composer 5/6/7
Transfer ProRes to MP4 for Mac OS X (Yosmite)
Editing MP4 in Sony Movie Studio Platinum 12/13
How to View AVI/MKV/VOB Movies on Nexus 10
Solution to Sony Movie Studio can't open AVI files
Transfer MKV/AVI/VOB/MOV videos to Nokia NI
Guide for Converting Video on Windows 8.1 with ease
Simply Copy Blu-ray movies to Surface Hub for playing
4K MXF/MOV/MP4 to Avid Media Composer workflow
Transcode AVI to ProRes 422/444/422 HQ for FCP 6/7/X
Tutorial: How to convert AVI to QuickTime MOV on Mac
Import Sony a7R II 4k xavc s files to Windows Movie Maker
Enable Premiere CC to ingest XDCAM MXF from Sony PDW-700
Source: How to Make iPhone videos editable in Premiere Pro
Related posts:
