Tips for editing VOB files in Windows Movie Maker smoothly
Summary: In this guide, you can get to know the easy method to convert VOB files to Windows Movie Maker friendly format for playing, editing easily.
As known to all, the latest Windows 7 and Windows 8 can play DVD .vob files properly. However, you can't edit VOB video with Windows Movie Maker. VOB is not supported by Windows Movie Maker and early Windows system. To import VOB to Windows Movie Maker for working beautifully, the easy solution is to convert VOB to WMV, the best format for Windows Movie Maker.
One of the tricky things about conversion is how good of quality you want it to have. If you wanna a lossless VOB to Windows Movie Maker conversion, a professional VOB file converter is required. Brorsoft Video Converter is just the right tool for you. It helps you effortlessly convert VOB files to Windows Movie Mkaer compatible .wmv with high quality, no matter your VOB files are ripped from your DVD discs, or downloaded online. After converted, you can easily import the converted WMV files to Windows Movie Maker for editing without hassle. Besides, this video converter also supports converting VOB/AVI/WMV/MKV/MPG as well as 4K videos for using in Sony Vegas Pro, Adobe Premiere Pro, Avid Media Composer, Pinnacle Studio and more NLEs(Get more Video and Audio Tips).
Convert VOB to Windows Movie Make step by step
1. Add VOB files
After installation of the best VOB to Windows Movie Maker converter run it and you'll see the program interface shown as below. Then import VOB files to the program by dragging and dropping, or by clicking the "Add Files" button to locate and load VOB files.
2. Choose WMV as output format
Press the Format box and select HD Video > WMV HD(*.wmv) on the dropdown menu as output format. Besides, you can also choose Divx HD(*.avi) as output if there is no .wmv codec installed on your PC.
Tip:. If you need to change the codec, resolution, frame rate and other settings, just click the "Settings" option at the bottom right corner.
3. Start converting VOB to WMV
The final step is to click the "Convert" button and all the added VOB files will be converted to WMV format for Windows Movie Maker.
After the conversion, find your converted video clips in the destination folder ("Open") and now you can play or edit the converted VOB videos with most Windows Movie Maker perfectly.
More Guides:
FFmpeg can't convert ProRes to MP4- Solution
How to convert VOB for Windows Movie Maker
Transfer ProRes to MP4 for Mac OS X (Yosmite)
Encode AVI videos to AIC .mov for iMovie editing
Guide: How to convert and import AVI files to iMovie
Editing Panasonic HC-X920 AVCHD in FCP 7, FCP X
How to convert and import MXF files to Davinci Resolve
Convert MXF videos to DaVinci Resolve acceptable format
How to rip Blu-ray/DVD movies to Oneplus One/Two in clicks
Recover iPhone data caused by updating to iOS 8.3 from iTunes
Converting WMV/AVI/VOB/MKV for playback on HTC One M9+
Getting Sony A7R II Media (4K XAVC S/AVCHD/MP4) into FCP 7/X
Source: Transfer VOB files to WMV for importing to Windows Movie Maker
1. Add VOB files
More Guides:
