Importing & Editing AVI in iMovie(Yosemite)
Summary: If you are puzzled by the problem that you can’t import AVI to iMovie directly, here recommend you the best AVI to iMovie converter to solve the incompatible problem.
You may get some AVI files and need to add these AVI files to iMovie for editing on Mac(Yosemite). However, when trying to import AVI to iMovie, only to find that there are many issues always around you. Let’s look at the following problems many happen:
1. AVI plays smoothly in QuickTime, but in iMovie, I get audio but no picture.
2. Import AVI clips into iMovie, but when play them, there's an image but no sound.
3. Imported an AVI file to iMovie, and it goes through the copying process, but nothing shows up on screen.
4. AVI played just fine in QuickTime, but they "grey out" in the import window.
These are the common problems encountered by many users who wanna use AVI files in iMovie. As a matter of fact, iMovie only reads AVI that both the audio and the video were compressed by using a codec that iMovie can recognize. If your AVI video files are not imported, it's because of the codec used to create the AVI file is not supported by iMovie, even if you have Perian installed, which only allows you to play AVI in QuickTime. If you want to edit AVI in iMovie, the easy option would be converting AVI files to iMovie compatible format, like Apple InterMediate Codec .mov.
The article would show you how to change AVI to iMovie editing-friendly format step by step with a professional Video Converter for Mac from Brorsoft, buy running it, there’s no need to set the codec yourself: the program has optimized presets for iMovie. Besides AVI, you can convert any video file like WMV, FLV, VOB, MPG, MKV to iMovie compatible format without loosing quality.
Guide: How to convert and import AVI files to iMovie
Step 1. After downloading, install and run this AVI converter for iMovie, just drag the AVI files to the software for converting.
Step 2. Click the format bar, and move mouse cursor to "iMovie and Final Cut Express -> Apple InterMediate Codec (AIC) (*.mov)".
Step 3. Finally, hit the big Convert button on bottom of the main windows and the conversion from AVI to iMovie will begin immediately.
More features of AVI to iMovie converter:
Adjust audio and video settings (optional)
The Mac video converter enables users to adjust audio and video settings before transcoding AVI to AIC .mov. Click “Settings” button, then you will enter the following interface, on which you are allowed to customize size, bit rate, frame rate, sample rate, and audio channel to your required ones.
2. Basic video editing (optional)
This Mac video converter has some simple edit functions like cropping, splitting, adding effects etc. so you can touch up the video with basic video editing functions.
After the conversion is complete, get the resulted files via clicking the Open button and then you can import converted AVI files to iMovie for further editing without any hassle.
Related guides:
How to convert VOB for Windows Movie Maker
Solve Windows Movie Maker Won't Play MKV Issue
Editing Panasonic HC-X920 AVCHD in FCP 7, FCP X
How to convert and import MXF files to Davinci Resolve
Convert MXF videos to DaVinci Resolve acceptable format
Add subtitles to AVI natively - Merging SRT with AVI files
How to rip Blu-ray/DVD movies to Oneplus One/Two in clicks
Transfer VOB files to WMV for importing to Windows Movie Maker
Getting Sony A7R II Media (4K XAVC S/AVCHD/MP4) into FCP 7/X
How to Successfully Play MKV in QuickTime on Mac/Win (Windows 10)?
Source: Encode AVI videos to AIC .mov for iMovie editing
Related guides:
