Importing H.265 footage into Premiere Pro CC/CS6/CS5
Summary: Does Premiere Pro have H.265 codec support? The answer is no. To edit H.265 in Premiere Pro CC/CS6, the easy workaround is to transcode H.265 to a more editing-friendly format, such an Adobe Premiere's MPEG-2. Here is the simple how-to.
Searching through the Adobe forum, you would find lots of threads that related to H.265 and Premiere Pro issue. Many guys are eager to know will Adobe Premiere Pro(CC) support direct import and editing of H.265 footage? Frustratingly, as far as we know, currently Adobe Premiere Pro lacks the support for H.265/HEVC codec. To work H.265 in Premiere Pro smoothly, a quick solution is to convert H.265 to Adobe Premiere Pro most compatible format no matter on Mac or Windows.
H.265(HEVC), a highly compressed format, is not easy for editing in Adobe Premiere Pro, even the latest Premiere Pro CC. Well, if you make the recordings editable before taking to the program, the incompatible error won’t happen any more. As far as I know, MPEG-2(.mpg) is the best format for Adobe Premiere Pro. Here you can download and apply Brorsoft Video Converter for Mac to achieve the goal in a fast way.
This professional H.265 converter is the solid tool to help users convert the H.265 footage like from Samsung NX1, NX500 to Adobe Premiere Pro without quality loss. It also offers the optimal profiles for Final Cut Pro, iMovie, Avid Media Composer, Adobe Premiere Elements and more. If you want to decode H.265 to Adobe Premiere on Windows, please get Brorsoft Video Converter. Download the program to start convert H.265 for Adobe Premiere Pro.
Read More: H.265 vs H.264 | H.265 to iMovie | Play H.265 using VLC
How to convert H.265 video to Premiere Pro CC/CS6/CS5
Step 1. Add H.265 files
Install and run the best H.265 to Premiere Pro converter and transfer your 4K H.265 recordings to the program no matter directly from a camera or from hard drive.
Step 2. Set output format
Click "Format" menu firstly and then follow "Adobe Premiere/Sony Vegas" to set MPEG-2 as the output format.
Step 3. Profile Settings
In case the default settings do not fit your requirement, you can click "Settings" button and enter "Profile Settings" panel to adjust video size, bit rate, frame rate, sample rate and audio channels. This H.265 converter app can maintain original 4K resolution for you if you need or downscale 4K to 1080p.
Step 4. Start converting H.265 to MPG
Click the "Convert" button; it would start transcoding H.265 to MPEG-2 for Premiere Pro immediately. After conversion, tap "Open" icon in the main interface to locate result video. Launch Adobe program to import converted H.265 footage to Adobe Premiere Pro CC/CS6/CS5 with easy editing.
Additional Tips:
Besides Adobe PP, this H.265 converter for Mac can also support converting H.265 files to Final Cut Pro, iMovie, Avid Media Composer, etc NLEs. What’s more, if you want to play H.265 videos in iTunes, QuickTime, VLC Media Player, this program is also the right app to help you convert and generate the optimal formats. Just choose a proper output format in the second step.
More topics:
How to add H.265 video files to iTunes
Workflow for 4K files in Adobe After Effects
How to Get iMovie Work With H.265/HEVC Footage
Workflow for Importing AJA Cion 4K video to FCP 7/6
H.264 in AE - Easily Work with H.264 files in After Effects
How to view MKV/AVI/VOB video files on Android device
Edit AJA Cion 4k videos in Adobe Premiere Pro CS6/CS5/CS4
[url=file:///D:/Maxthon2/Plugin/Html2UBB/How%20to%20Convert%20Samsung%20NX500/NX1%204K%20H.265%20to%20H.264%20.MP4]How to Convert Samsung NX500/NX1 4K H.265 to H.264 .MP4[/url]
Convert VOB to Android and Play VOB on Android Tablet/Phone
Convert Samsung NX500 H.265/HEVC files to Adobe Premiere Pro
Source:How to convert H.265 video to Premiere Pro CC/CS6/CS5
Additional Tips:
More topics:
