Blackmagic URSA 4K to Adobe Premiere Pro workflow
The URSA 4K Digital Cinema Camera with active EF Mount from Blackmagic Design features a form factor that is designed to make it flexible enough to use on productions of all sizes. Blackmagic Ursa gives you two recording modes: Apple ProRes 422 HQ and losslessly compressed CinemaDNG RAW. However, something turns to be frustrated; the Blackmagic Ursa 4K ProRes videos are not accepted by Adobe Premiere Pro. This article just aims to give you some tips and tricks for importing and editing Blackmagic URSA 4K in Premiere Pro beautifully.
[Guide]How to Solve Blackmagic Ursa 4K incompatibility issues with Adobe Premiere Pro
As a matter of fact, ProRes in a MOV file format from Blackmagic URSA is beyond the compatibility of Adobe Premiere Pro. What’s more, handling 4K video in Adobe Premiere Pro (CS4/CS5/CS6/CC) is extremely hardware intensive. You can’t get a flawless workflow in most cases. To solve the problem, you need to convert BlackMagic Ursa 4K ProRes files to Premiere Pro supported format like MPEG-2 with Brorsoft 4K Video Converter for Mac.
The program is an easy-to-use yet professional Blackmagic 4K Converter. It’s able to convert 4K ProRes files to Adobe Premiere more compatible format MPEG-2 without quality loss. Plus, this 4K video app can also encode any 4K videos including XAVC/XAVC S, 4K MP4, 4K MOV, etc to FCP, iMovie, Avid Media Composer, etc. For Windows users, please get Brorsoft Video Converter. Just download it and follow the step-by-step guide to get the work done.
1. Download, install and run the BlackMagic 4K Converter Mac; click "Add Videos" icon to load your source videos from Blackmagic URSA.
2. Click on the “Format” bar and choose a best editable format. For editing Blackmagic 4K in Adobe Premiere, choose Adobe Premiere/Sony Vegas --> MPEG-2(*.mpg) as output format.
3. Set proper video/ audio parameters. Click the “Settings” button and set proper video/ audio parameters. You can reset set the video size, bitrate and fame rate. You can keep original 4K resolution or adjust video size to 2K or 1080 full HD as you need.
4. Hit the convert button, it will start converting 4K ProRs 422 (HQ) from Blackmagic URSA to Premiere Pro compatible format immediately. Soon after the conversion, just click “Open” button to get the generated files for natively editing in Adobe Premiere Pro CC/CS6/CS5 perfectly.
More Topics:
How to Edit 4K in Final Cut Pro
How to Edit 4K in Sony Vegas Pro
Best 4K Ultra HD Video Converter
Best Way to Play Quicktime MOV on Galaxy S6 Edge
Play and Edit iPhone videos on Windows Movie Maker
Editing Nikon 1 V2/D5100/D3100/D800 MOV in Premiere
iPhone videos (H.264) not working in Sony Vegas- Solution
Downscale Blackmagic URSA 4K to 1080p for editing in FCP 7
Convert Sony 3D AVCHD MTS to side-by-side 3D MP4 or MKV
Import Blackmagic DNxHD MXF files to Final Cut Pro 7/X Editing
How to import Tivo videos to iTunes for Easy Playback on iPhone/iPad
Source: Import Blackmagic Ursa 4K footage to Premiere Pro CC/CS6/CS5
More Topics:
