How to Get iMovie work with 4K videos from Canon XC10
"Does iMovie support 4K videos? I got a lot of 4K videos from Canon XC10 and tried to open these 4K videos in iMovie. Nothing happened but got some error message. What's going on?"
Canon’s XC10 is a compact form-factor camera with a 1' sensor that shoots 4K UHD to Cfast and 1920×1080 HD to SD cards in Canon's new XFAVC codec which is a new proprietary video format for the efficient recording of high-image-quality 4K, 2K and HD video footage. It adopts the MPEG-4 AVC/H.264 as video codec, which seems not so compatible with iMovie or other NLEs on Mac.
For those who need to edit Canon XC10 4K files in iMovie, we would suggest them to encode XC10 4K MXF footage to AIC .mov before editing in iMovie. I tried several converters, and found a powerful third party program for you-Brorsoft Video Converter for Mac.
In general, this ideal converter can deal with various common videos including XFAVC MXF, MOV, MKV, MTS, MP4 .etc for playing and editing. With it, you can freely transcode Canon XC10 4K XFAVC videos to AIC MOV for editing in iMovie. Besides AIC iMovie codec, it also offers other optimized codecs for NLEs such as Apple ProRes for FCP, MPEG-2 for Premiere, DNxHD for Avid and so on. Now, download the software online and follow the below guide to start Canon XC10 4K to iMovie conversion.
How to Change Canon XC10 4K XFAVC videos to AIC for iMovie
1. Add original video files
Go to the "File" menu, choose "Add Video/Audio" button to import original Canon XC10 4K XFAVC videos. Or drag files to the program directly.
2. Select output format
You can choose iMovie/FCE --> Apple InterMediate Codec(AIC) (*.mov) as the output format. The output format is designed for iMovie 11/09/08 and Final Cut Express specially.
3. (Optional) Adjust Parameters
Access to settings page by clicking "Settings" button to adjust the output parameters, such as resolution, frame rate, etc to get a prefect output video.
4. Start conversion
Click the "Convert" button to start the Canon XC10 4K XFAVC videos to AIC .mov conversion.
After the conversion, click "Open" to locate the result videos and then import the new file into iMovie or FCE with smooth editing without any trouble.
Read More:
How to import Sony a77II XAVC S to FCP 7/X
Open/edit AVI files in Premiere Pro CC/CS6/CS5/CS4
How to Import MXF files to Adobe Premiere Elements
Canon XF Plugin for Final Cut Pro (X)| FAQs & Answers
How to Convert Canon MXF for Sony Vegas further editing
Use Sony FDR-AX30 4k in Premiere Pro CC/CS6 smoothly
How to open and edit Sony A77 II footage in Adobe Premiere
Convert Sony FDR-AX30 XAVC S to FCP X, Final Cut Pro 7/X
Sony FDR-AX30 Video Converting/Editing Tips in iMovie 11/09/08
Converting Sony NEX-FS700 60p/50p AVCHD to Apple ProRes MOV
Edit Canon C500 MXF files in Final Cut Pro 6/7/X (Yosemite & Mavericks)
Source: Enable iMovie work with Canon XC10 4K XFAVC videos
4. Start conversion
Read More:
