Using Panasonic DMC-CM1 4K files in Adobe Premiere Pro
[size="4"] Have troubles while importing Panasonic DMC-CM1 4K footage into Premiere Pro for further editing? Fortunately, here is the easy workflow for this. Let's keep reading...[/size]
If you are considering a new 4K camcorder, Panasonic DMC-CM1 should be on your list. It features a large 1-inch MOS sensor and is capable of 4K video recording at 15fps, as well as Full HD recording at 30fps. Well, no matter you’re using or going to have Panasonic Lumix CM1, you may wanna know the compatibility of the Panasonic DMC-CM1 4K and Premiere Pro. In this page, I will give you the answer.
Adobe Premiere Pro will work with some MP4 files, but not all. The problem is that they are not the same, which may contain different video/codec and various video frame rates. The MP4 footage from Panasonic DMC-CM1 seems not to be an ideal editing format for Premiere Pro. What’s more, editing 4K in Adobe Premiere Pro is extremely hardware intensive. It’s not so easy to work with Panasonic DMC-CM1 4K clips in Premiere Pro. In this case, you can try converting the 4K files with some third-party software like Brorsoft Video Converter for Mac(It’s the app I’m using.).
Overall, Brorsoft’s Video Converter Mac can enable you to effortlessly transcode Panasonic DMC-CM1 4K MP4 videos to MPEG-2 files, which will create a Premiere friendly file format for smooth editing. Besides Premiere Pro, this software can also export DNxHD for Avid MC, Apple ProRes for Final Cut Pro, AIC for iMovie/Final Cut Express and more NLE systems for native editing. If you are on Windows, just turn to Brorsoft Video Converter. Now get the step-by-step instruction below.
Premiere Pro CC/CS6/CS5 and Panasonic DMC-CM1 Best Workflow
Step 1: Install and launch the Panasonic DMC-CM1 video converter on Mac and click the "Add" button to load CM1 separate 4k .mp4 files for converting.
Step 2: Click "Format" bar and choose Adobe Premiere/Sony Vegas -> MPEG-2(*.mpg) as output format for editing raw 4K in Adobe with natively supported video codec.
Step 3: To get a perfect video for editing in Premier Pro, you’d better press the Settings icon to set the video size as 1920*1080, frame rate as 30fps in the Profiles Settings panel. Note: If you want to get original 4K resolution, just keep the video size as original.
Step 4: After above settings, hit "Convert" button to start transcoding Panasonic DMC-CM1 4K MP4 to MPEG-2 for directly importing to Premier Pro.
Once the process completes, you can click "Open" to locate the .mpg files ready to be imported into Adobe Premiere Pro CC/CS6/CS5.5/CS4/CS3.
Additional Tips:
This 4K MP4 to Premiere Pro Converter can also export edit-friendly format for FCP, iMovie, Avid, etc NLEs. If you wanna transcode Panasonic DMC-CM1 footage to FCP X or FCP 6/7, choose Final Cut Pro > Apple ProRes 422 (*.mov); for iMovie or FCE 4, choose the "iMovie and Final Cut Express -> Apple InterMediate Codec (AIC) (*.mov)"; and for Avid MC, "Avid Media Composer > Avid DNxHD(*.mov)" is the choice.
More Guides:
How to Downscale Ultra HD 4K to 1080p Easily
How to rip and copy a DVD to Yoga Tablet 2 (Pro)
Transcode Sony/Panasonic 50p/60p MTS to Vegas Pro
How to Work Blackmagic Cinema 4K in Premiere Pro
Panasonic GH4 4K Workflow with Adobe Premiere Pro
Convert Sony HX90V XAVC S to ProRes for Final Cut Pro
How to Prep GoPro (4K) Footage For Editing In Premiere Pro
MKV(DTS audio, subtitle support) files on Microsoft Surface 2
Converting DNxHD to ProRes 422 on Mac(Yosemite, Mavericks)
How to Import media files from Sony EX1 to Final Cut Pro X?(Yosemite)
Convet GoRro Hero2/Hero3 footage for Editing in Windows Movie Maker
Source: Enable Premiere Pro to ingest Panasonic DMC-CM1 4K MP4 video
Additional Tips:
More Guides:
