How to Use and Edit DivX movie in Sony Vegas Pro 12
Some users are in trouble using DivX codec in Sony Vegas, this article will show you the solution to open DivX to Sony Vegas for editing using a DivX Converter.
As a Windows based audio video editing program, it stands to reason that Sony Vegas should import, open and play AVI (a common video format under Windows). However, various issues occur when importing, such as vegas pro 10 and Divx issue:
Q1: After upgrading to Vegas Pro 10.0a 64-bit, I can no longer open in the timeline or trimmer any file encoded with the DivX codec. Further, I can no longer customize an .avi render to use the DivX codec. I upgraded the DivX Pro codec to 6.9.2, as part of the DivX Pro 8 bundle. That was no help.
Is there some "registration" of the codecs that must be accomplished before Vegas Pro 10.0a will recognize and use them?
Q2: I have over 200 AVI files that I want to edit them with Vegas 10, most are divx. However, I can't even import divx files into Vegas! Only the audio content is shown in the timeline. Then I tried Virtualdub and that didn't work either please help.
Then how to use DivX codec in Sony Vegas Pro?
In fact,Sony Vegas doesn't support DivX codec. That means if you want to import DivX to Sony Vegas Pro for editing, you will be failed. In order to edit your DivX in Sony Vegas smoothly, you should transcode DivX to MPEG-2/WMV format, which is best supported by Vegas Pro.
Pavtube Divx Video Converter is the best choice to achieve your goal, I have used this tools for some time, it can deal nearly all kinds of videos filed including DivX files for Sony Vegas Pro easily, that is to convert Divx video to MPEG-2/WMV format, and then you can edit DivX files smoothly in Sony Vegas Pro. Now, we just intro an really good and easy way to help you convert and import your Divx files to Sony Vegas.
Step 1. Download DixX to Vegas Pro converter, follow the prompts to install the program. Click "Add" to load DixX video files or directly drag the files into file list. If you want to join several DivX files together, check the "Merge into one file" box.
Step 2. Click "Format" bar to determine output format. For smoothly editing in Sony Vegas Pro, you are recommended to choose Adobe Premiere/Sony Vegas -> WMV (VC-1) (*.wmv) or MPEG-2(*.mpg), this format is best for Sony Vegas Pro editing.
Step 3. If you would like to customize the video and audio parameters, you can click "settings", adjust the parameters as you want, like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels.
Step 4. Click "Convert" to start to convert DivX-formatted videos to Sony Vegas Pro.
With this DixX to Sony Vegas Pro converter, it becomes easy for you to convert DivX AVI video to Sony Vegas Pro 12 smoothly for editing.
Read more:
Source: http://digisns.com/2014/12/convert-bandicam-avi-to-sony-movie-studio/
Read more:
- Handling the Canon EOS-5D h.264 MOV files with Sony Vegas
- Convert PWM-F55/F5 XAVC to Sony Vegas without Quality Loss
- Import Panasonic DVCPRO P2 MXF files to Sony Vegas Pro 11
- Will FCP X Handle 4K from GH4 Camera?
- Load Sony HDR-XR150 mts to Pinnacle Studio 17
- Convert HD M2TS movies to smaller mp4 files for local playing
