Backup Transcendence Blu-ray for Playback on Galaxy Note 4 with Intact Quality
This article center on the best solution to backup, transfer and play Transcendence Blu-ray disc to the coming Galaxy Note 4 for playing.
The Galaxy Note 4 might also be the first mainstream Samsung phone with a "Quad HD" display. Pre-release rumors point to the display size staying around 5.7 inches, same as the Galaxy Note 3, but upping the resolution to 2560x1440 pixels.
As a Blu-ray fan who happens to own a Transcendence which was released recently,you will find playing Transcendence Blu-ray on the coming Galaxy Note 4 directly on the phone is irrealizable since it has no BD drive on Galaxy Note 4. But this doesn't mean you cannot achieve this goal. There are silver linings.
You can rip Transcendence Blu-ray to Galaxy Note 4 viewable video format beforehand so as to access your converted movie to this Samsung gadget without limitation. And to fulfill Transcendence Blu-ray to Galaxy Note 4 conversion task, you need to prepare a piece of professional Blu-ray ripping software.
Here Pavtube BDMagic especially designed for Galaxy users to quickly convert Blu-ray and DVD movies into Galaxy Note 4 playable MP4 format effortlessly with intact quality. Plus, the sticking point is that this tool allows you to easily make a copy of your Blu-ray and DVD discs in few clicks. If you are a Mac user, you can use its equivalent Mac version – Pavtube BDMagic for Mac. Doubtful? You will not if you check this tip out:
Best solution of ripping/transferring Transcendence Blu-ray movies to play on Galaxy Note 4
FYI: Note: BD drive is required for ripping Blu-ray disc.
Step 1. Import Blu-ray disc.
Click "Load files" to choose import from BD drive. It will detect and check the main title automatically; so keep it as default unless you want to include tidbits.
Step 2. Chose "Samsung Galaxy Note (*.mp4)" as target format.
Click the drop-down list besides Format, you can find many presets for different devices, editing programs and media player. Let’s choose "Samsung" in left area and select "Samsung Galaxy Note(*.mp4)" as target video format.
Step 3. Customize video specs. (Optional)
Pavtube Blu-ray to Galaxy Note 4 Ripper also offers a editor window to let you free set eo specs; click "Settings" to customize output file size, bitrate, frame rate and sample rate. Here you can set video size to "1280*720" for playing Blu-ray on Galaxy Note 4 with [font=serif]2560x1440[/font] screen.
Step 4. Start Conversion.
Click the "Convert" button to start converting Blu-ray to MP4 so you can watch them in Galaxy Note 4 smoothly. Wait for moments, then click "Open output folder" to locate the converted file quickly.
Source:http://movie-tips-review.blogspot.com/2014/08/convert-transcendence-blu-ray-to-galaxy-note-4.html
Learn More:
Easily Convert DVD to the coming Galaxy Note 4
Copy Blu-ray Movie to Samsung Galaxy YP-G70
Watch Blu-ray Movies on Samsung Galaxy Tab S 10.5/8.4
Watch Blu-ray/DVD Movies on Galaxy Tab 3 with more than one language
