Watch 2014 World Cup soccer match on Smart TV/HDTV/UHD 4K TV
 Postovano: 17.06.2014 14:21
Postovano: 17.06.2014 14:21Watch downloaded and recorded 2014 World Cup soccer match on Smart TV/HDTV/UHD 4K TV
The following Video Converter Ultimate guide will show how to watch downloaded and recorded 2014 World Cup soccer match on Smart TV/HDTV/UHD 4K TV.
In recent days, World Cup groups released their squad lists successively and fans has gone to the heated discussion to guest the most splendid match in 2014 FIFA World Cup and prepared to wait for live according to the new released squad list. Actually, fans prefer to watch live but not every fan can stay at home whole day for World Cup live. However, network lag is annoying when watching World Cup online videos. What is the best solution?
If you own a 4K TV, no matter Smart TV or HDTV, you can download the match videos in HD or SD and play them smoothly with TV. Then how to watch and play 2014 FIFA World Cup on 4KTV without limitation?
In order to stream 2014 World Cup Video files to Smart TV, UHD 4K TV or HDTV for playback, you may have to convert 2014 World Cup Video to Smart TV, UHD 4K TV or HDTV playable format. Along with some help from third-party software. With Pavtube Video Converter Ultimate, a great all-in-one 2014 World Cup Video Converter, you can easily achieve your goal smoothly.
The following guide shares with you how to encode download 2014 World Cup games video to Smart TV, UHD 4K TV or HDTV for playback on Mac step-by-step.
Step 1. Install and launch the 2014 World Cup Video Converter for 4K TV, and click "Add Video" button to load your 2014 World Cup Video files. The software supports batch converison so that you can add several 2014 World Cup Video files to convert at one time.
Tip: Preview video and Take a snapshot
With the built-in player, you can preview the added video before you convert the video. Also, it is very easy for you to take snapshot of your beloved movie screen. The image will be saved in jpg format.
Step 2. Click on "Format" boarder to set output format.
Now that we're converting 2014 World Cup Video for Smart TV, UHD 4K TV or HDTV, a recommended format is "DivX AVI - Audio Video Interleaved(DivX)(*.avi)" or "MKV(Matroska) Video (*.mkv)" or "H.264 Video(*.mp4)" from "Common Video" option.
1. Get adjustable quality to put video/audio on 4KTV by clicking "Settings"
Customized video settings, so you can set the Video Codec, Frame Rate, Video Bitrate, Frame Size.
As for the Frame Size, if you don’t find what you want, you are available to input your own resolution in Width(pixels) * Height(pixels). Set audio settings, including Audio Codec, Sample Rate, Channels, Audio Bitrate. It is very easy to use!!
2. Crop and Edit video for 4KTV by clicking "Edit"
Video Cropping alters the dimensions of a video clip. You can eliminate areas of the video to emphasize a particular focal point within the frame such as highlighting a character by removing ancillary imagery or removing unwanted backdrops.
This World Cup Video Converter also allows you to change video brightness, contrast, saturation, and apply other effects including mirror, flip vertical, rotate by 90 degrees clockwise and flip, rotate by 90 degrees clockwise, rotate by 90 degrees counterclockwise, rotate by 90 degrees counterclockwise and flip, noise, and sharpen.
Step 3. Finally click on "Convert" button to start converting 2014 World Cup Video to MP4/MKV/AVI format.
In this way, you can get 2014 World Cup Video files playable on 4KTV without problems. We hope this short article will bring some new multimedia life to your Smart TV, UHD 4K TV or HDTV.
See Also:
Convert Blu-ray DVD to ATV on Mac for playing via HDTV
Rip/Store my Blu-ray collection on NAS server for easy usage with Tablet, PC and TV
Stream TV recordings (Tivo shows) to Samsung Galaxy Tab 4 for playback
Source:Watch downloaded and recorded 2014 World Cup soccer match on Smart TV/HDTV/UHD 4K TV
See Also:
