Mac Sony XAVC File Merger-Combine/Join/Merge XAVC Files
UFUSoft XAVC Converter for Mac is a great Mac XAVC File Joiner which not only helps you to perfectly convert or edit Sony PMW-F55/Sony PMW-F5 XAVC files, but also gives you the easiest way to combine, merge, join and convert XAVC files into only one with one click on Mac OS. So if you have lots of XAVC files, and want to joined xavc files, or also keep 5.1 channels, please try this all-in-one Sony XAVC File Joiner right now.
You can keep on reading this article to help you process it step by step:First, free download this Mac XAVC File Joiner here, install and run it. (For Windows User: XAVC File Joiner.)
Step 1: Add XAVC video files you want to merge into this program.
Click “Add” button to load Sony PMW-F55/Sony PMW-F5 XAVC video files into this program, batch conversion is supported, so you can add more than one at one time.
Step 2: Merge/Join/Combine Sony XAVC videos to only one file and select output format.
Once all the XAVC video files are loaded, you only need to select all files and click Merge on the main interface, only one click. Then you can select the output format you need from the drop-down list “Format”. If you need, you can also set destination folder from the “Browse”. If not, the output files will be saved in the default folder automatically.
Step 3: Click the “Convert” button to start video conversion and Sony XAVC files joining at the same time.
In the conversion process window, you can see some useful information you may want to know, like Time elapse, Estimated left, Generated size and estimated size, and choose shut down computer after conversion.
Tip1: This Mac Sony XAVC File Joiner is also a good editor. If you want to edit the videos before merging or joining, you can click the “Edit” button to trim, crop, add effect, deinterlace, replace audio, flip video and so on.
Tip2: This Mac Sony XAVC File Joiner offers you the special function to adjust audio and video parameters by clicking the “Settings” button. Then you can select codec, bit rate, frame rate, size, resolution like 1080i, 720p, 1080p, etc, and the aspect ration and so on.Wish this article help you to merge into one with ease on your Mac.
Read More :
Blu-ray Video/Media Player Software for Windows 7/8/8.1/Vista
2014 Best Blu-ray Player Video/Media Software for Windows 8.1 Blue/8 Review
Best Blu-ray Video/Media Player Software for Windows 8 PC
What is Cinavia and How to play Cinavia protected Blu-ray disc?
How to Decrypt and Play Protected Blu-ray Disks on Computer with Ease?
How to Import/Edit Canon VIXIA HF G30 AVCHD videos in FCP X/7/6 on Mac?
Wrap/Convert Sony HDR-PJ380 AVCHD to HD AVI for Playing on PC
Transcode/Convert AVCHD MTS/M2TS to DNxHD MOV for Avid MC on Mac
Read More :
