Nikon MOV to Prores 4444 encoding and to DVD burning
ProRes 4444 Converter - Encode Nikon D610 mov to Apple Prores 4444
Summary: This brief guide will show you the easy way to convert Nikon D610 H.264 MOV footages to FCP with Apple ProRes 4444 codec for editing without any issues and burn them to DVD on Mac.
The power of a pro-level Nikon FX-format camera is available in a compact, lightweight, HD-SLR body. Using the Nikon D610, capture stunning full-frame images and broadcast-quality 1080p videos with the 24.3MP FX-format CMOS sensor. It provides full HD D-Movie recording with manual exposure control and full time autofocus, background blur, exceptional low-light performance, and extensive compatibility with NIKKOR lenses.
However, Nikon D610 videos are saved in 1080p .mov format with H.264 codec, which is highly compressed, so you can not easily and directly import and edit Nikon D610 HD mov files on Mac with Final Cut Pro.
In order to edit Nikon D610 H.264 clips in FCP without crashing problem and avoid rendering, you'd better transcode the Nikon 1080p mov footages to FCP native format, say, Apple Prores Codec. This article will share the way to convert Nikon D610 H.264 mov footages to Prores 4444 encoded MOV file for FCP and burn to DVD on Mac.
Part 1: Convert Nikon D610 H.264 MOV to FCP
Best Software choice:
Pavtube HD Video Converter for Mac - a top Nikon H.264 Video Converter for Mac.
The Mac Nikon Video to FCP Converter is an easy to use yet professional H.264 MOV Converter on Mac OS X which can not only transcode Nikon D610 mov videos to Prores 4444 codec for FCP editing, but also provide simple video editing functions for you. Besides, the program can also convert HD videos from HD camcorders or DVs (like JVC, Panasonic, Sony and Cannon) for editing in Final Cut Pro, Final Cut Pro X, Final Cut Express, iMovie, Avid, Adobe Premiere etc. Below is how.
Solve problem about editing Nikon D610 H.264 mov footage in FCP
Step 1: Install and launch this Mac H.264 MOV Converter and load D610 H.264 MOV clips to the program. You can click either “Add Video” button or “Add from folder” button to load source MOV files.
If you want to combine the loaded MOV clips into one file, simply tick off the checkbox before “Merge into one file”.
Step 2: Click the format bar, and move mouse cursor to “Final Cut Pro > Apple ProRes 4444 (*.mov)” as output format if you want to get high qualtiy.
The Apple ProRes 4444 codec offers the utmost possible quality for 4:4:4 sources and roughly 50 percent higher than the data rate of Apple ProRes 422 (HQ).
* Learn more Apple ProRes, please refer to Types of Apple ProRes Codecs
* Read How to edit D610 h.264 mov in FCP 6/7 with ProRes 422 LT, ProRes 422 HQ codec
2. By clicking “Settings” button, you are able to enter the “Profile Settings” panel to adjust video and audio parameters for your Nikon MOV source files, including video size, bit rate, frame rate and more.
Step 3: Click “Convert” button to start transcoding Nikon D610 mov footage to Apple ProRes 4444 Codec for Final Cut Pro.
Once the process completes, you are able to ingest your Nikon D610 mov footage to Final Cut Pro for further editing on Mac without any incompatibility issues.
Part 2: How to burn Nikon D610 mov to DVD on Mac
Now Pavtube DVD Creator for Mac adds support for mov files burning, it can burn single file or folder structure videos, you can burn D610 mov to DVD in few steps, just follow it:
1. Install Pavtube DVD Creator for Mac, connect your DVD Writer and insert a blank DVD. Add your h.264 mov videos into the 550D DVD Creator for Mac.
Tips: You can customize photo slideshow transitions by clicking the photo and choose "edit" add background music by enable Background Music button.
2. Edit movie clip and Customize your DVD menu. You can edit your videos with trim, crop, watermark, effect settings, audio replacing settings features.
3. Preview Created DVD-Video and click burn button to start your marvelous burning process from Nikon D610 mov files into DVD on Mac.
Good news! At Christmas & New Year Big Deal, if you get HD Video Converter for Mac, you can get DVD Creator for free. Take a look now and grasp this opportunity before Feb.10, 2014! Never miss!
See also:
Get Nikon D610 footages readable by Apple Aperture 3-
Edit Nikon D610 MOV in After Effects CS6
Transcode/Import Nikon D60 MOV to Avid MC/Xpress Pro
From: http://phyllis018.deviantart.com/art/Encode-Nikon-D610-MOV-to-ProRes-4444-Burn-on-Mac-427014063
See also:
