Convert Sony NEX-VG10/VG20/VG30 AVCHD to iMovie on Mavericks
PostPostovano: 26.11.2013 10:13
od HaileyLi
Does iMovie support import AVCHD footage from Sony NEX-VG10/VG20/VG30 without rendering?
Description: If you want to edit AVCHD .mts files shot by Sony NEX-VG10/VG20/VG30 smoothly in iMovie, here is right for you. Go to following article to get the instruction.
Sony NEX-VG10/VG20/VG30, which offer excellent image and video quality with interchangeable-lens systems, capture footages in both AVCHD format high definition video and MPEG-2 format standard definition video. Most users prefer to choose AVCHD format in order to get high quality videos. However, many users will face the similar issue about editing in iMovie on Mac OS X as below:
"I'm strictly an amateur hobbyist hoping to make some good videos for a hugely popular blog. I wanted to covert the AVCHD 60p clips from my recently purchased Sony NEX-VG10 to a mac friendly format for editing in iMovie 11."
That is probably because the AVCHD .mts files cannot be recognized by iMovie. In this case, we can count on third-party software to transcode them to a compatible format for iMovie. Here comes Pavtube MTS/M2TS Converter for Mac Mavericks, a professional MTS to iMovie Converter tool for converting MTS/M2TS/M2T/TS files to a variety of video formats. It will help to transcode Sony NEX-VG10/VG20/VG30 AVCHD .mts files to iMovie friendly AIC codec MOV format, which is intermediate format that features high performance and quality, being less processor-intensive to work with on Mac OS X. With it you are able to edit AVCHD .mts files in iMovie smoothly and then share a better video with friends or post the edited videos to blog. Now follow me to learn how to convert AVCHD .mts files to iMovie on Mac OS X Mavericks.
You are free to download the Mac MTS to iMovie Converter and install on your Mac. Then go to the guide here:
1. Load AVCHD .mts files to the MTS to iMovie Converter.
Tips: You can joint multiple AVCHD files on to one output file by checking Merge into one file on the interface.
2. Select AIC MOV format for iMovie.
Many output format here and you are recommended to select "AIC .mov" files under "iMovie and Final Cut Express" because it best compatible format for iMovie.
3. Adjust output settings and edit the video. (Optional)
Settings: You are allowed to change the parameters of video and audio, such as Size, Bitrate, Frame Rate, etc.
Edit: Here you are able to edit the video before conversion. You can cut off the unnecessary part of the video in Trim, crop the video, add watermark or 3D effect, attach subtitle and so on.
4. Convert AVCHD MTS to iMovie.
Click "Convert" button to start conversion and then click "Open" button to locate the generated files for iMovie.
If you want to convert more videos and movies in different formats, you could try iMedia Converter for Mac, which is capable of converting both various HD videos and latest DVD/Blu-ray. You are also allowed to 1:1 backup the whole discs for further playback or editing. 20% discount will be provided if you get it during the time of Thanksgiving Promotion 2013.
Good news! In this promotion page, if you get MTS/M2TS Converter for Mac, you can get FLV/F4V Converter for Mac free which can help you to edit and play flash video (flv, f4v) on Mac with ease. Take a look now and grasp this opportunity! Never miss!
More related:
Transcode Sony VG30 60p MTS to FCP/Quicktime on Mac
Best Solution to use Sony NEX-VG20 footage in Premiere Pro
Import and Cut Sony VG900 AVCHD footage in Avid MC and Xpress Pro
Get iMovie and Final Cut support Sony NEX-VG30 AVCHD files
Source: http://mediaconverting.blogspot.com/2013/09/import-avchd-mts-files-to-imovie.html
