Encode MKV to AVI in perfect audio/video synchronization
Summary: This tutorial is relevant for converting MKV files to AVI video in perfect audio/video sync without quality loss, so that you can control your MKV movie files anywhere you want them.
MKV has become a popular video format for movies, TV shows, Music TV and many other forms. But many customers who have digital players or editing programs cannot use the MKV file as there gadgets or software do not support the format. So, there arises a need to convert MKV file to any other format like AVI so that all music and video lovers can enjoy the audios and videos to the fullest.
To encode MKV files, you will need a practical converter to make it. Although there are lots of MKV converters in the market, which one to choose is a big headache, because most of these programs have problems one or another like video, audio out of sync, quality loss...
Well, Brorsoft MKV Converter is a powerful MKV to AVI converter which can fast convert MKV to AVI with high quality. Don’t worry about the quality loss. It supports batch conversion and setting relative output parameters before starting to convert mkv to avi. It can not only finish conversion between MKV and AVI, but also guarantee the output files without audio and video out of sync issues. For Mac users, please get MKV Converter for Mac.
Now, I will tell you how to convert MKV to AVI via the help of Brorsoft MKV Converter in detail, just read on it to get what you need at will.
Step 1. Add MKV to converter Download, install the MKV to AVI Converter. As long as you launch it, the following main interface will pop up. Now you can click on “Add” button to import MKV files which you want to convert into this program.
Tip: if you want to join all the MKV files you loaded as a single file, you can tick checkbox “Merge into one file”.
Step 2. Choose AVI as output format Hit the drop-down list of “Format” to select AVI format from Common Video as output. Of course, you can also select HD AVI as the output format keeping 1080p full HD quality.
Step 3. Set advanced settings By clicking the Settings icon, you can adjust video and audio parameters like codec, bit rate, frame rate, sample rate, etc., in that way, you can take charge of the size and quality of the output AVI files. In principle, the larger input values, the better output quality, but the corresponding larger file size.
Step 4. Start MKV to AVI conversion As soon as all the above settings are completed, you can press “Convert” button to start conversion. You can follow the conversion process via the pop-up windows.
After conversion is done, simply click "Completed" to back to main interface, and click "Open" button to find generated AVI videos.
See more:
How to Open MKV video files in Premiere Pro
How to Import MKV files to iMovie 11
How to transcode MKV to ProRes for FCP
An easy solution to ripping Blu-ray ISO to MP4 video
Losslessly Rip Blu-ray to 1080p MKV on Mac Mavericks
Compress/Convert MKV to Galaxy S4/Galaxy Note 8.0 MP4 Format
Source:Encode MKV to AVI in perfect audio/video synchronization
See more:
