Multitrack MXF Mixer-Convert MXF to multi audio channels MP4
Multitracks MXF Converter and Mixer-Convert MXF to multi audio channels MP4
Description: If you want to transcode your MXF footages to MP4 for better playback and meanwhile remain multiple audio tracks from original MXF files, you may prefer to follow this article because it will show you the way out.
Original from http://encode-video-for-editing.over-blog.com/convert-mix-mxf-to-multi-audio-tracks-mp4
MXF is a prevailing video format with high definition shot by professional camcorders like Panasonic P2, Canon XF and Sony XDCAM series camcorders. And it is widely used in both professional broadcast video and amateurish video made by amateur hobbyist. You may have shot lots of MXF footages with several audio tracks for both web and television of corporation, or just for sharing with friends and family. But you find that it is hard to play on TV or portable devices. So it is neccessary to convert it to MP4, a friendly format for playback. To find a helper to get it done is easy. Pavtube MXF Converter for Mac can help you to convert MXF videos to any audio and video formats.
However, the output video preserving all audio tracks from MXF videos may conform to your need better. And you do not want to loss any audio tracks in output MP4 videos. That is exactly what Pavtube iMixMXF can do for you.
iMixMXF, which supports Mac OS X 10.9 Mavericks, is a professional MXF Converter and Mixer tool for helping converting MXF videos to any other video and audio formats for playback or further editing. And meanwhile it supports saving output video with the preservation of multiple audio tracks of original MXF videos. Other than multi-track preserving features, it is also capable of mixing several audio tracks into one track. Go to try those wonderful functions now.
The following instruction will tell you how to transcode MXF to Multi channel audio MP4 on Mac Mavericks. Now download and install the best Multitracks MXF Converter and Mixer, and then follow the instruction.
Step 1. Load MXF footages.
Run Pavtube iMixMXF on your Mac, click "+" button to load the MXF video files or load the MXF folder.
Tips: "Merge into one file" can help you to convert several MXF videos into one video. Just select the tasks you need and then check "Merge into one file", you will get one combination of those videos.
Step 2. Select multi-track MP4 format.
Click "Format" menu to find "Multi-track Video", choose "Multi-track MP4 (*.mp4)" for output.
Tips: Besides multi-track MP4, there are also multi-track MKV, multi-track MOV and Apple ProRes for you to choose for playback or editing.
Convert Canon XF MXF to MKV and Embed SRT/ASS Subtitle
Mix Multi-track MXF into on track on Win and Mac
Convert Sony XDCAM MXF to Multi-track ProRes for FCP
Transcode/Mix Multi audio tracks MXF to MOV on Mac
Convert multi-track Panasonic P2 MXF to ProRes
Step 3. Set multiple audio tracks for MP4 video.
If you do not need all audio tracks for output, click "Settings" button you are allowed to uncheck the audio tracks you do not want for output. And you can choose to keep default settings or adjust parameters, like codec, bitrate, channels, etc, according to your different requirements.
Tips: If you need to mix multiple audio tracks into one track, go to check "Mix into one track" on the lower left. Conversely uncheck it you will get multiple audio tracks separately.
Step 4. Start conversion.
Click "Convert" button to start conversion, after a while go to "Open" button to locate the generated MP4 videos with multiple audio tracks.
Just enjoy converted MP4 videos with multiple audio tracks.
Multi audio channels MXF Converter and Mixer related guides:
How to convert Canon MXF to FCP 6/7 with multiple audio tracks preserved?
Audio Mixer: How to Mix multiple audio tracks MXF into one track on Mac?
How to convert multi audio channels Panasonic P2 MXF file on Mac OS X?
Convert Panasonic P2 MXF to iMovie AIC MOV
