Import Canon C300 MXF to FCP, iMovie, Premiere Pro, Avid
Summary: With this awesome guide, you can smoothly import and edit Canon C300 MXF files in FCP, iMovie, Premiere Pro, Avid by transcoding/converting C300 MXF to an ideal editable format on Mac.
Source:Canon C300 Workflow - FCP, iMovie, Premiere Pro, Avid
As a new Canon C300 user, you may be confused with the C300 workflow. Here I’m looking at importing C300 footage into various non-linear editing systems (NLE). The C300 uses the same workflow as the Canon XF series of cameras (which includes the XF305, XF300, XF105 and XF100), because it records in the same format. Below, I outline how to import Canon C300 MXF into Avid Media Composer, Final Cut Pro 6/7/X, Adobe Premiere and iMovie. Keep reading for a brief how-to.
As far as I know, MXF is not a good editing format for NLE system including iMovie, Final Cut Express, Final Cut Pro, Avid Media Composer, Adobe Premiere Pro, etc. Then how to import Canon C300 videos to iMovie, FCP, Avid for editing without any issue? Well, if you make the recordings editable before taking to the program, the incompatible error won’t happen any more. Here you can download and apply Brorsoft MXF Converter for Mac to achieve the goal effortlessly.
This Canon MXF Converter for Mac is the solid tool to help users to transcode MXF files to a format you want on Mac OS X. It offers the optimal preset profiles for Final Cut Pro 6/7 and FCP X, Avid Media Composer, Adobe Premiere Pro, iMovie, FCE and more. And there is no need to worry about the quality loss. Plus, it also provides you the editing functions like trimming, cropping, adding watermark, etc. If you are having the Canon C300 editing issues on Windows, please get MXF Converter.
Convert and import Canon C300 mxf footage into Avid, Premiere, iMovie, FCP
STEP 1: You need to download, install and run the smart Canon MXF Converter Mac and transfer your MXF recordings to the program for converting.
Tip: You can join several MXF clips together via checking the “Merge into one file” box.
STEP 2: Click on the “Format”bar and choose a best editable format.
a. For editing Canon C300 MXF in FCP, select Final Cut Pro > Apple ProRes 422 (*.mov) as the output format.
b. To import Canon C300 footage in Avid MC, choose Avid Media Composer->Avid DNxHD(*.mov).
c. Choose iMovie and Final Cut Express > Apple Intermediate Codec(AIC) (*.mov) as output format, so that you can transcode C300 MXF to AIC .mov for editing smoothly.
d. To solve Canon C300 .mxf and Adobe Premiere Pro incompatibility issues, please select Adobe Premiere/Sony Vegas > MPEG-2 (*.mpg) as the target format.
STEP 3: Adjust the video and audio parameters including the Bitrate of Video&Audio, Video Size, Sample Rate, Frame Rate, Audio Channels, etc., by clicking the Settings button for getting the best quality before starting conversion.
STEP 4: After the settings, click “Convert” button to start the Canon MXF to Avid, FCP, Adobe, iMovie conversion on Mac OS X.
Once the conversion finished, you can smoothly transfer the converted files to FCP/Avid/Premiere/iMovie.
Get more solutions for Panasonic/Canon P2 MXF/MXF importing and editing issues, please link to Brorsoft MXF Colum.
More Tips and Tricks:
Upload Canon XF100/XF105/XF300/XF305 MXF files to Pinnacle Studio
Solve Canon C300 MXF to Adobe Premiere Pro CS6 issues
Editing Canon C300 MXF in Avid Media Composer
Convert Canon C300 1080i MXF to AIC for editing with FCE
Import Canon XF300/C300 MXF footages to After Effects CS6
Import Canon EOS C300 1080i MXF to Sony Vegas Pro
Premiere Pro CS5.5/CS4/CS3 and Sony PMW-EX1R Workflow
Import Canon EOS Rebel T3i (600d) & T4i (650d) MOV to WMM
How to import Canon XF300 MXF footage to Final Cut Pro X
Solution to Adobe Premiere Pro CS6 no audios from M2TS files
Sony PMW-EX1R Footage Import Issues with FCP X
2014 Christmas Promotional Items
