Digital Copy to Windows 8-Rip Digital Copy to Iconia W700
Digital Copy to Windows 8-Ripping BD/DVD Digital Copy to Acer Iconia W700
Summary: See in this guide how to remove DRM from BD/DVD Digital Copy Movie and convert BD/DVD Digital Copies to Acer Iconia W700 support video playback format with best Digital Copy to Iconia W700 Converter
When you buy a DVD or Blu-Ray, usually you receive a digital version of the movie- known as Digital Copy. Generally, Digital Copy is a fast and easy way to enjoy your favorite movies, anytime, anywhere on your PC, Mac, or compatible portable device. However, the Acer Iconia W700 is not a listed compatible portable device. To bring a Digital Copy of your movies on the go, you need an iPad/iPhone or ZuneHD, which is granted to play digital copy contents.
While Acer Iconia W700 can not play digital copy movies directly, there's a get around. With DRM removal tool ChewTune, you can convert digital copy to free video that plays on any device you like. Below shows you how to get BD/DVD Digital Copy ready for Acer Iconia W700 to play back:
Step-by-step instruction: how to download Digital Copy movie to Acer Iconia W700?
1. Download/Transfer Digital Copy movie to your computer. The Digital Copy is located on a stand-alone disc and is Mac & PC compatible.
2. Get DRM removal tool installed on your PC/Mac:
Digital Copy to Iconia W700 Converter | Digital Copy to Iconia W700 for Mac
If the downloaded version of ChewTune may not contain Acer Iconia W700 profile, you can download a patch for best settings.
3. Run Pavtube ChewTune as a Digital Copy to Acer Iconia W700 Converter. Click "Add video" button to import digital copy files.
4. After you install the profile patch, click "Format" and select an output format for the Acer Iconia W700. Here I choose "Acer>> Acer Iconia Tab A700 Video(*.mp4)".
If you wanna get much better image quality, you can click "Settings" and set the video bite rate higher than 2500. But notice that the output file size will vary based on video bit rate. In general, the higher video bit rate, the larger output file size, and vice versa.
5. Click "Convert" button to start convert BD/DVD Digital Copy to Iconia W700 friendly video format.
6. When the conversion task is finished, you can click "Open" button to get the final output files for your Acer Iconia W700 and transfer the converted videos to Acer Iconia W700.
This program cannot convert unplayable files (damaged, unauthorized, etc.).
The DRM removing process may mislead your anti-virus software to falsely report virus/worm. Please ignore the report to keep on converting DRM video.
When converting digital copy movie from iTunes library, you need to set iTunes not to remember playback position.
If you want to copy Blu-ray movies to Acer Iconia W700 for playback, pls view the guide: How to Rip and Transfer Blu-rays to Acer Iconia W700?
Buy One Get Another Free? Yes, just join Pavtube's Special Offer to get the promotion.
Only $75 = ChewTune + Blu-ray Ultimate (Saving $19)
