konvertovanje hd mova
pozdrav..listao sam forum medjutim nisam nasao sto mi treba.. ovakva je situacija..snimao sam video sa canonom 500d koji snima u .mov format a codec h.264. taj codec stvarno zeza kad je u pitanju editovanja videa i nasao sam na netu par savjeta da je najbolje da ga konvertujem u neki drugi npr mpeg visoke kvalitete ili avi..u avi mi radi, ali izadje od prvobitnih 30mb na 1gb, sto je previse..u mpeg kad exportujem pomocu after effectsa, ne mogu ostaviti file u rezoluciji 720p nego ga automatski baca u sd rezoluciju..premierom sa pokusao export u mpeg i mogu da ostavim rezoluciju, medjutim osjetim gubitak kvalitete, tamnija slika itd (a koristio sam vasa uputstva sa stranice za sto bolju kompresiju)..
pitanje je, kako da konvertujem u mpeg, sa sto manjim gubitkom kvalitete, velicina i nije toliko bitna al ipak 1gb je previse za 1 file a imam ih oko 100..da li postoji neki program ili nesto..na vimeo.com sam nasao ovo:
...First, He instructs you to import your video files:
Plug your camera's compact Flash card into your computer using a card reader (don't use iPhoto etc.)
Drag the entire contents of the DCIM folder from your compact Flash card onto your external hard drive.
Discard the thumbnail files (.THM Files).
Then, once your video files are on the computer, they are ready for conversion:
Download the free software, MPEG streamclip and open it.
To convert all of your video files at once, go to "List" select "Batch List" and then select "Add Files". Next, select all of the files you wish to convert.
Click "To Batch" select "Export to QuickTime" and hit "OK".
You do not want to "join all the files" as it is easier to organize them separately, nor do you want to"Fix time code breaks".
Create a new folder and click "Select".
Now, you are ready to choose the settings that will convert your video files into a better format to edit with:
Philip Bloom recommends you use Apple XDCAM EX 1080p30 (35 Mb/s VBR) if you don't plan on editing the file later with software such as Cinema Tools.
Turn Quality to 100%.
Make sure it is Unscaled and deselect "Interlaced Scaling" and click on "To Batch".
Click "Go".
fazon je ovaj..skinuo sam ovaj konverter, ali nemam ovaj codec Apple XDCAM EX 1080p30 (35 Mb/s VBR), jednostavno ga nemam u listi..
dalje pise ovako:
Use ProRes 422 as a substitute to Apple XDCAM EX 1080p30 for a higher quality yet less compressed (larger file) format!
medjutim nemam ni ovaj..pomoc pliz!
ako nista, gdje mogu da skinem ove appleove codece?
Click "Go".
dalje pise ovako:
